It didn’t say he has -44 offset that I saw. I don’t mind doing a little trimming if needed. Also he has a 2.5” level and I only have a 2” [emoji848]
Lol it’ll never fit...and 90% of x12s are -44 offset.
So lots of cutting would be in store! Hmm maybe a different route lol.
24x12 -44 minor trimming level kit
2” or 2.5” level. Let’s see this “minor” trimming. Also are those 33x12.5s?
3 inch spacers up front 3 inch blocks in back I’ll take a picture of it tomorrow when it’s daylight
Yea that makes sense. This dude wanted to fit them with just a 2” is the reason I told him it wouldn’t
Ah ok i see what you saying
Now I’m looking at a 20x9 with -12 backspacing with 276/65/20 tires. That should fit better
-12 is offset, backspacing is in inches - how far away the edge of the wheel to the strut housing (i believe). Look online for offset calculators and you will see diagrams..
go here:  https://www.1010tires.com/Tools/Wheel-Offset-Calculator#
Offset is.. look at the wheel down the center for example 12 inch wide rim will be center at 6 inches on either side right?
So + and - directions from that center line is the offset.
That combo will fit better and will push the wheels out maybe 1.5 inces past the fender im guessing.
I think if you are going negative offset you can run wider wheels so 20x10 should work.
Looking at my 20x9  0 wheels, i could have ran 20x10 and 285 tires.
Edited by Ozer
Hey folks,
need a recommendation for black lugs for my Hostile Sprockets
thanks!
Gorilla Nuts
Replaced the OEM running boards with these. İ like them better.7b091282d4acb1ffeb382656605fa46b.jpg7b0d1b8917b91de94a125f11aaca64c6.jpg
Sent from my Pixel XL using Tapatalk
I’m running 20x10 with -24 on 295/65R20s and I rub but nothing a grinder, Hammer, and some good paint won’t fix!
    • Those are parts changers. It can get expensive though. I was a mechanic for 30 yrs. My truck has made this noise since new. I really don`t know what it is. It really doesn`t bother me. I`m still in warranty but have not brought it to the dealer.   I`m not buying the oil pump prime thing. Screw the TSB. I believe it`s in the trans pump gears. They rattle when that piss poor ULV oil drains off after a while. I believe those sharp tooth gears, with backlash, can rattle when dry. Not a vane style oil pump. Wonder who`s right? Me, or the TSB?🤔   Maybe I`m wrong?
    • Sounds about right. I miss the days of mechanics lol.
    • On the PCM side, blue PCM connector, pin 18, solid gray color (no stripe) wire circuit 435.  That is the EGR low circuit which an issue on that line (be it the wiring, the PCM or the EGR valve or system performance) will trigger P0401 when it tests that code.     There is also a VERY old TSB that states to make sure you clear the DTCs ANY time the PCM is unplugged, reprogrammed, or if the EGR valve is unplugged or replaced as the PCM has an auto zero function in the PCM for the EGR pintle data   61-65-59: SMU - SECTION 6E - ENGINE CONTROLS - CLEAR DTC'S - (Nov 25, 1996)   "CLEAR ANY DTCS FROM THE VCM ANYTIME AFTER DOING VCM REPLACEMENT/ PROGRAMMING, TURNING THE IGNITION ON WHILE THE EGR VALVE IS DISCONNECTED, OR REPLACING THE EGR VALVE."   Some diagnostic aid notes in the GM diag on P0401 for a 1995 S10 Blazer:   Diagnostic Aids Notice: In order to prevent further damage if the EGR valve shows signs of excessive heat, check the exhaust system for blockage (possibly a plugged converter) using the procedure found on the restricted exhaust system check. If the exhaust system is restricted, repair the cause; one of which might be an injector which is open due to one of the following reasons: Stuck Grounded driver circuit Check the oil for possible fuel contamination if a stuck open fuel injector is found. Poor connection or damaged harness - Inspect VCM harness connectors for the following conditions: Backed out terminal BL 18 Improper mating Broken locks Improperly formed or damaged terminal Poor terminal to wire connection Damaged harness Intermittent test - If connections and harness check OK, monitor a digital voltmeter connected between terminal BL 18 and ground while moving related connectors and wiring harness. If the failure is induced, the voltage reading will change.
    • maybe get a service manual off ebay?  or check charm.li (website) or subscribe to alldata.com for it?
    • This biggest difference in a HM oil is in contains some  "Seal Conditioner". DEXOS oils and most shelf oils are "Dry" oils which over time harden seals. "Seal Conditioner" is more times than not, an Ester. Addition will soften the seals over time but will not repair one that leaks or has cracked. Esters also provide some cleaning but these HM oils don't contain enough to solve out hard deposits. Just the soft stuff.  Also a function of an Ester.    Ester's are not 'allowed' as a 'co-base" by license. Weird, right?  A certain amount is allowed as an additive. Bunch of game playing is what it is. It's why HM oils don't have a DEXOS approval.    DEXOS is a license 'with' a specification but is not a specification. Never was, never will be. It's GM's slot machine always paying the house. Use what you like.
