Thanks man for the reply. At this time I only want to lower the rear with shackles. No plans for the front.
Sounds like a plan, go for the 4600.
I have a 2017 CCSB 4X4 with the 6.2L (L86) and Max Trailering Pkg. I tow a 34' Airstream trailer (9,100 pounds and 1,100 tongue weight. I want to maintain the factory ride height, but I'd like a more controlled ride, especially towing. I want the damping to be more controlled...not harsh.
Would the 4600 series Bilsteins be an improvement over the factory shocks?
Thanks,
Steve
Yes, the 4600 are a nice improvement over stock. The 5100 will work as well, but the 4600 is a little tighter which should help when you are loaded up
Are their any Bilstein's for lifted trucks? I have a 7" lift on mine but I'm not too impressed with the shocks that came with it.
Yes, we have several extended length options for the rear up to 8". In the front, all Bilstein offers is the 4600, the 5100 and the upcoming 6112
awesome! Well I want some right now. [emoji23]
I bought a full set of 5100s. Installed the rear and have been happy and impressed. I have been putting off the fronts because I am going back and forth on the level to install the fronts. I would like the highest setting but have heard that it affects ride quality and put them on the third setting then I have also heard it doesn't. I'd like to get the front as close to the back as possible in hight but I don't want the ride to be too harsh. I do pull a trailer occasionally but plan to install air bags on the rear to level the truck out. Any info would be appreciated. Thanks.
Edited by spartantx117
I did and still feel and see the vibration.
I have a front set of 4600s with only 4K miles on them that I will sell super cheap. I had them on with a spacer but replaced that setup with 5100s. I dont recommend the 4600s with a spacer - not rough, but very sensitive to any street problems.
If your in Houston let me know and we can meet to save shipping.
I have 5100's on all 4 corners with the front set at the 3rd highest setting (1.24" of lift and still roughly .75" of rake). Still running stock tires (Wrangler SRAs) and 18" wheels. I love the way the truck rides now. It came with the rancho shocks and the first kit I had was the RC 2.5". The ride quality with the 5100s is way, way better than the RC+Rancho set up. It's also way better than just Ranchos and no leveling kit. The best way for me to describe it is this:
The ride is less bouncy (really, not bouncy) going slow over rocks and things like speed bumps or driveway curbs and more controlled at higher speeds. The truck is stays planted when going over shittily repaired Florida potholes in a 45-55 mph turn. It is not jarring in any sense around town, and off-road it is less fatiguing because it's no longer underdamped and bouncy. It also handles washboard dirt roads 1 million times better. I thought the damn dash was going to vibrate out with the ranchos. It's not butter smooth now, but it is acceptable.
My advice to anyone with Rancho shocks looking to level, or just improve ride quality, is to go with 5100s. I am probably going to pop mine up to the highest setting soon and add a 1" block to the rear. This should bring the front up to 1.85" and give about 1.25" of rake. Then I want 275/70R18 KO2's!
anyone with the zone 6.5 kit or 4" kit try swapping the front shocks with bilsteins?
Curious if you have pictures of your truck with the 5100s at 1.25". Im looking to do the same
Any vibrator trucks switch to bilsteins and have good luck?
I did and yes much better however I have added larger tires rated at E. Only time I feel slight vibs is going up or down a hill. I'd say I'm 99% free of vibrations
Maybe if I can't get the dealership to fix mine I'll look into this.
My OEM "ranchos" ride like a 79 cutlass on the highway. And not in a good way.
Still trying to figure out out to post pictures. Hope this works.
Stock:
12088319_10207472785843519_6024149688108
Approximately 500 lbs in the bed:
15727300_10155742491613009_3461975650526
Towing roughly 5,500 lbs with about 200 lbs in the bed:
16002933_10211398219776914_9219318257804
Unfortunately I don't have any pics with just the shocks and nothing in the bed. I'll try to get some.
Stock:
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
