Do you notice and ride difference when not towing with this kit, at the 5-10min psi? I have a new kit sitting in the garage waiting to be installed. I have the 3" rear blocks and bilstein rears as well.
Not at all, you can squeeze then when that low. Do you have the same exact kit? Are you installing a compressor? If not, take the bolts out of your rear license plate and run your valves through the holes then nut back on the plate. looks clean and easy to get to.
Yes it the same kit. No compressor. Only tow a couple times a month at most so don't see the need to spend the extra $ on it.
Did you consider a rear block guys? For the amount of times I tow, the extra 1" was enough and doesn't kill the look.
Edited by tanner709
I did, but I'm glad I went with the airlift, feels a bit more stable when towing. I also am not a huge fan of the rake.
Edited by Bwoodkid
put a set of 5100 on my truck (rear) to replace the Rancho's wow what a difference
Did it stay at stock height when you swapped? I am wanting to get rid of these rancho shocks and go with something better....I have a level up front with nothing in the back and would hope that it stays pretty close and keeps me level.
It stayed the same in the rear they say they are for trucks with stock to 1" lift
Just added the 5100's all the way around. Front is at max setting and I added a Motofab 1" block in the rear. I have to say that I am ok with the front ride but the ass end of the truck seems to bounce or "skitter" over bumps. It did this with the Rancho's as well. I was hoping that replacing with the 5100's would stop this. I torqued all the nuts on the U bolts to 60 lbs and verified the shocks were mounted correctly, (boots down) and functional. With some weight in the back, it rides fine. I understand its a truck and will ride like one but I am disappointed in what I expected of the upgrade. My father and brother both have Tundra's and man do they ride great. Its a nice solid bump and then done. Not a skitter like my Sierra. Has anyone else noticed this and have recommendations? Or am I expecting too much?
i was told the boots go up and that's the way i mounted them, the truck handles and rides much better than with the Ranchos
I also made the switch a few months ago. Front's maxed and added a 2" (1"over stock") block in the rear. I'll echo what everyone says, the truck drives much better but there are some conditions where the 5100's are less forgiving. I carry a full tool box, back rack, ladder rack, and misc stuff in the bed and I think the weight definitely helps my ride. The few trips I've taken everything off/rode unweighted, I'm not nearly as impressed with the ride.
I replaced my fronts about 6k miles ago. I am starting to get a little clunk going over bumps on the drivers side. Has anyone else had this problem? I torqued everything to spec at install and rechecked it last night. It feels like it is the stabilizer link. But I can't figure it out.
Sent from my SM-G900V using Tapatalk
To clarify, the rear 5100s can be used at stock height, or stock +1"?
If stock height, would this require an alignment due to slight length difference from stock shock to 5100?
If everything is torqued, I would also suspect the link. Maybe remove it and check for play.
Yes they can.
No you wouldn't need one since you are not changing the angle. If you added a block, (even +1") you would need an alignment. Somehow that changes the front angles enough to require one. Or so I am told from the guy that aligned mine.
Edited by tuckersnator
What is the going price for a set of Bilstein on a 1500 with 2" drop shackles?
Amazon has the set of 4 for $355.76 and free shipping.
AutoAnything has the set of four for $376.60 and free shipping
Edited by Eddie 70
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
