1 hour ago, Josh said:
We have strict rules that you continue to skirt.  Our moderators hide all postings that are not from Supporting Vendors.  They are just doing their job.
Directly from our site guidelines:
"Only Supporting Vendors, who have paid for the exclusive rights to advertise on this forum, may commercially advertise vehicles, products, and services for sale. Any commercial posting done by members who are not a Supporting Vendor will have their post deleted. We also do not allow any posts which solicit personal donations, no matter how worthy the cause."
This has been the rule for 15+ years.
For the record, this company MRT Motorsports is no longer a supporting vendor and has not been for months.
I hadn't seen every post, but weren't they just being helpful and answering questions?  I didn't see any advertising from them.
Honestly as much I have seen them pushing business on here, Im not sure why they are not maintaining a sponsor membership.
I could careless about the sponsorship stuff...now all the updates on 6112s are non existent. :rolleyes:
I get it...the forum needs to make money to keep in business.  But these posts I am SURE brought a ton of folks via search engine.  Literally the only thing that comes up on google -- and the thread has been deleted.
Edited by aaronarf
Have a 15 ecsb ltz 4x4 with 6.2 and leer cap, have 2"rake now,36.5 front and 38.5 rear, want to leave 1-1/4-1 1/2"rake for tow/hauling. Thoughts on bilstein 5100 set at top and a 1" block in back or 3rd setting an no block in back, stay with 275/55-20 tire. Worried at top height I'd only have 3/4-1inch rake and would be nose high with 2-300lbs in bed?
Looking to lift the front end of my 2014 Z71 CC up a little bit and I am wanting to avoid putting any strain on any of the suspension components. I have read through this entire thread and I have seen that with the 5100 at the top setting they seem to ride a little bit more rough, which I am not worried about. The thing I am worried about is how they perform in the cold (around -15F temps)? Are they even more stiff?
I really think mine ride stiffer in the cold we've had in Michigan this winter. This is the first winter on these shocks.
The ride, for me at least, had become very choppy feeling.
Then leave it stock, any level whether with a spacer or shocks will still add some strain. The closer you stay to stock the better, so a 1.8" level will be better than those who go 2-2.5. I wouldn't worry much about it though if you are staying on the lower side and you aren't beating it up off road all the time (ie it is mainly a DD on the street) and you don't go overly large with the tires, weights or wheel offset then it should last for a long time before anything needs replacing.
BTW, good on you for reading and doing research. So many read a page or two if that then just ask a repetitive question as they are lazy so kudos!
Tyler
Edited by amxguy1970
Giving props for searching and reading
Tyler
Thanks for the response. As mentioned above it sounds like the ride is a little more harsh when it is cold. I just don't like the appearance of how the truck sits but I do like the ride quality of the z71. I'll most likely try to find a leveling kit that raises maybe an 1-1/2" or so
Usually I read these and other forums almost obsessively so I don't make people mad for repeating other things
I have a 1" block in the rear with 5100s in both the front and rear, set at the hghest setting in the front. There is no ass dragging with 2-300 lbs. I'll try to get a pick of around 2000lb in the bed to show you that it is not drastic...
Yes, I know - well above payload.
Edited by tanner709
Sorry guys. I read through 12 pages of this thread and couldn't find what I was looking for. Here's my question. I installed a 2" rough country level with the stock Rancho shocks. The ride got much stiffer. I really don't like it. What way is the best way to go here? Would installing the 5100 on the stock setting give me a better ride? Or is there a different shock that would smooth me out? OR..Just remove the lift all together? Thanks.
Any shock designed to run 2" longer than stock should improve your ride. They get stiffer for more control once taken outside of the designed normal ride area.
While I'm hear, the 6112 kit still coming soon, like the last 2 years? What a joke, makes me want to buy anything else for allowing this to happen.
thanks for the reply, i think i will set bilsteins at 3/4 in front, truck is not a daily driver and when it is used it will be either loaded with hunting equipment and dogs or towing 4 atv's.
I've seen them listed as available within the last few days so they must be out finally.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 592 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
