14 hours ago, jgraves13 said:
No issues but you could take out the 2" spacer you have under your struts now and put the Bilsteins on the top setting to get the same thing
Thats what I was figuring. I would remove that rough country spacer.    Are you thinking ill need extended brake lines?
So...where is the best price for a full set of 5100's? Ebay has a set for about $350 but I'd rather buy from a retailer/reseller if possible.
Thanks in advance!
If you don't have extended brake lines now, I don't think you'd need them with the Bilsteins
correct, not using them now.   cool im most likely going to get those bilsteins!
Thanks in advance!
I do not see anything wrong with purchasing the 5100 set on Ebay, as long as the seller is reputable.
Why would you buy them on ebay when they are the same price on Amazon.  I paid 354.00 for my entire set on Amazon.
Thanks in advance!
Meant to copy in this.  Not you Dan.
Link? I see a set on Amazon for $366.20
Have you ever used www.camelcamelcamel.com ? Be ready to have your mind blown!
Looks like the low is $343.51 but the price has gone up about 5%.
Camel Camel Camel Bilstein Shocks 5100
Looks like MRT has it for 352 OTD.
I have not used camelcamel.com but I bought mine on Amazon in April for 356.00 from BoostProjects.
Edited by 4weight
Hey Guys,
Did some digging but couldnt come up with much.
I assume everything is the same for the 2019 limited editions? Anyone know off hand which control arms came on this model? Just picked up my 2019 sierra limeted z71 a month ago and debating the 5100's
Thanks in advance!
Our price is right under $350 delivered
Use code GMTRUCKS
Fronts - BILSTEIN Truck & Off Road - B8 5100 Series Shocks (24-238304)
Rears - BILSTEIN Truck & Off Road - B8 5100 Series Shocks (33-238319)
Rear 5160s - BILSTEIN Truck & Off Road - B8 5160 Series Shocks (25-242515)
