its just different type of valving but in a nutshell yeah you think so.....theory is ride is smoother over rougher terrain and lil firm on small stuff
check it out though there are tons of topics and info, most do say billys and icons are bit firm as daily driver, but some love em so just depends on what you want to feel
https://accutuneoffroad.com/articles/digressive-vs-linear-vs-progressive-pistons-shock-valving/
Edited by Dunn
think eibachs are progressive valved and bilsteins are digressive....different way of valving
digressive starts out firm then gets softer where progressive starts out softer and ramps up at end, just different approaches and everyone feels things differently, so just depends on what type you are
sucks cuz eibach had sale lil ways back and was $389 for all 4 corners, am sure it will come back at some point
Hello, this prices is with spring?
Enviado desde mi iPhone utilizando Tapatalk
i didnt even know these were a thing lol, however they are out of my price range as im just wanting to do a small level to my truck while i save up for a decent lift kit. so initially i was set on the bilstein 5100s all around. well then i came across the eibach pro truck lift kit and it peeked my interest due to the beefy springs. so now im torn wether i should got with the eibach kit or the bilsteins. so i figured id ask if there was a spring people were using with these 5100s apart from the oem one. something that could sill save me a few bucks. since the 5100s all around come out to 334 and the pro truck kit is 586.
Hello, U$ 334 kit Bilstein?
some dude bought a set on here when sale happened.....I believe eibach has springs ready now for 2019 T1 but at that time no they didn't....I don't know if they were selling other kits with springs for same price.....but sale is over now, another will come at some point....
eibach make springs for a ton of of other companies shocks and coilovers…..chances are pretty high if you buy a quality kit from anyone it will have eibach springs.....
Edited by Dunn
I now have about 6k miles on my 6112s/5160 combo and can’t be happier with the combo. I’m even now running my E load range KO2s at 65 psi and the ride is still better than I remember the stock setup in every situation. I like my truck a lot more with the upgraded suspension.
In what way do you find the front end better? Softer? More progressive? Less of a top-out feeling going over bigger stuff I hope?
I only have the 5100s on mine since the 6112 kit wasn’t available when I leveled mine. Just debating whether it’ll be worth it or not do throw the 6112s on there now.
Every situation feels more controlled. I felt like the stock suspension only handled very small bumps well. Anything more and things banged and crashed or got out of control quickly. I had mentioned before here that after replacing my suspension I noticed I was driving around town faster than before just because it felt better. I had to consciously dial it back. Even at freeway speeds the Bilstein suspension doesn’t seem to bottom out like I remember the old stuff would and I’m talking more like g-outs from quick elevation changes.
I do think the 6112s and probably most shocks need to break in some which is why when you first get them installed it might not seem as awesome as you hoped. That I didn’t feel the need to lower my tire pressures after the last time I towed says a lot and I have put about 2k miles on the truck at 65psi.
That’s good the hear! With my 5100s it felt more controlled but the stock coil doesn’t seem to be good at all. Almost like it’s maki  nag the shock do too much work. I’ll have to get the 6112 kit when my funds allow it. Should be an easy swap without having to align it since I already have the 5100 adjustables on there in the max height.
where is the best place to order 6112's? im ordering 5100 for the rear and 6112 for the front to replace my RC level. im going to also switch UCR since i have the stamped steel and my 285/60 20 ridge grapplers rub them
cant decide between CST or Cognito UCRS
May also take a look at readylifts UCAs. Seem a bit cheaper but we’ll made
I bought my 6112s from Battleborn. They are or at least were a forum sponsor and had a discount code for forum members.
I just ordered a set of the 5100's .. they were only about $20 more than the 4600's and I like the look of them better than the yellow and blue.  I do not have a lift kit in it and don't plan on doing so.  My understanding is that by using the higher grooves on the strut body, it will lift the front slightly.   I may consider doing that cause it wouldn't bother me to raise the front slightly.  I don't think I want to go to the highest setting but was wondering if the 2nd or 3rd notch would be a noticeable change in height.  Also will using either of those notches produce a harsher ride.  Lastly does this put more wear or strain on other components.  Is it changing the suspension geometry at all or doesn't it affect that?  Seems like most recommendations are for the 3rd or 4th notch and not many for the 2nd....why is that?
Thanks in advance for any input
-RC
I have Kryptonite UCAs and they are pretty nice. Similar balljoint to the Cognitos and the warranty is really good on them. I got em on ebay from rudys performance parts.
When I spoke with a tech at Bilstein earlier this week, he said they tested their 5100s with stock components including UCAs and there were no issues. He mentioned that they probably stuck with 1.8” as the highest because much higher could create problems with stock components (some of their 5100s for certain trucks go up to 2.5-2.75”)
Trying to think through it logically, as long as the 5100 shock stops the downward travel I don’t think a ball joint could pop out of the stock UCA... but if the UCA contacting the bump stop is what’s stops the downward travel and the shock and weight of the tires/wheel is trying to push the wheel down further, I could see how the ball joint would be popped out (more like pulled out).
Does that sound like sound reasoning?
    RyGuy43
    RyGuy43
  • Who's Online   2 Members, 0 Anonymous, 405 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
