So my 2005 Sierra with the 4.8 had the same issues. It got so bad that after driving just down the road I would lose oil pressure and the engine would be knocking like crazy. I did my research and decided it was probably the oil pump. After hours and hours of changing that out (this was a difficult job as stated before) I started it up and it was idling at 40 and was responsive and running good. Well the next day on my 30 minute drive home from work the oil pressure dropped down extremely low after I got off of the highway and the engine started knocking. It only does it after driving for about half an hour, at first start up and quick drives the pressure stays right above 40 and is running like a dream. If I would have known about these strainer screens I would have done that also but I'm not sure if that is the problem. Any and all input is welcomed!
@Mmarch
what oil and spec are you using?
did you only notice the oil press loss randomly 1 day or did it gradually get worse?
how many oil changes & filters have you gone through since it began happening? Tried using something different?
When you replaced the oil pump, you also replaced the pickup tube Oring?
if all of that checks out you can try heavier oil. Hard to believe you have bearing probs if the oil and air filter was replaced on schedule.
Here is a video I just made with the proper way to fix this concern. Hope this helps.
  • 3 months later...
I have a 1999 gmc 1500 suburban sle have replaced oil pump and sending unit and still have issues with mu oil gauge then check gauges light comes on what else do i need to do. The motor is 5.7
Edited by Richard Lee Ledesma
If you have this problem, be prepared to advocate for yourself. I'm having a similar issue, or maybe the same one on my 2013 Silverado 5.3. At about 60K the oil pressure dropped to near zero. The local dealer replaced the oil pump under warranty and said that was unusual but not unheard of. At 90K, same thing. The dealer (a different one, because we had moved) replaced the oil pump (also under warranty) and said they didn't see a reason for the second pump to fail. I asked about the screen, bypass, etc., and they said it was all fine, and that they didn't see anything else wrong, but that if the problem returned we'd be covered. Now at 97K the same thing has happened, but this time they say there's a cam bearing issue causing the pumps to fail and that GM won't cover the repair under warranty because we're 62 months into ownership and this is a different problem. This truck has had excellent care since new, has never been used to tow, and gets mainly highway miles. It's really frustrating that GM won't cover the problem even though it first appeared well within the warranty period. So, if you have this issue, be prepared to be really insistent about finding the root cause when it's under warranty, because if they can get the truck out of the warranty period, you're on your own. Thanks for nothing, GM. We've purchased more than 10 new GM vehicles over the years, but it looks like my next new truck will be a Ford.
New here, just purchased 06 Silverado 1500 5.3L 134K miles. My issue is the oil pressure gauge is pegged @ 80. When I start it it goes to 80 and stays there no fluctuation at all. The other day I start it and the gauge goes to 30 then drops to 0 and stays there. I listen for lifter noise and nothing, I shut off and restart goes to 30 then back to 0 and stays. Start again and same thing, still no noise from engine so I drive. After a few miles the gauge goes back to 80 and stays there again with no fluctuation when slowing to idle or speeding up.
Do you think this could be the sending unit? Could it be the gauge in the dash. Any thought will be appreciated
Jeff.
If you can get a oil pressure tester set, you can find out for sure what the exact oil pressure is. If you don't have one you can rent one from an auto parts store. Simply find the correct fitting and screw it in. On the older 5.3 L test port is at bottom of where oil filter housing is.
It can be the oil pressure sensor switch which is in the engine block or the sending unit itself or gauges etc.
Test oil pressure with gauge first
stepper motor on gauge would be my guess or Oil pressure sender.. both cheap easy fixes
My first try will be the pressure sending unit. Isn't it alot of trouble to tear the dash apart to do the stepper motor?
no, entire gauge cluster comes out in 2 min.  The motor on the back is easy to change... see youtube for video
Thanks watching now.
  • 6 months later...
Common problem doesn't seem to matter what oil I use had this 3 times now always change oil before required full synthetic I've heard of people just removing the screen but I'm to uneasy to do that
Check out my above post/video on how to fix this the right way. If you blow out the passage it tends to fix it. Now, if you just have low oil pressure it could be bacuse of multiple different things from the oil pump pickup oring, the cam bearings failing, the oil pressure relief stuck or weak. But if you do it the way I posted above... I normally don't have any return problems.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
