I'm new to the group but I just put an oil pump in my 01 Silverado. And my pressure goes up when you hit gas peddle. But cold or hot it will still fall if it idles. Is it something simple. Or is the 145000+ miles the end??? Any advice would be greatly appreciated and thank you.
Edited by Mr.B
You need to provide more detail on your specific issue.
Does it have good oil pressure on start up, like 40+ psi and then it just falls to zero or does it level off to a certain number?
Can you confirm the readings with a manual oil pressure gauge or is your oil pressure sensor new??
  • 3 weeks later...
On 2/27/2015 at 12:53 PM, MaverickZ71 said:
On a 2007-2013 Silverado/Sierra 1500 4x4, in order to drop the oilpan to install a new, clean screen, don't you have to remove the front 4 wheel drive differential and remove a frame brace (transmission brace?) just to be able to drop the oilpan? If so, it seems like a heckuva lot of work just to be able to drop the oilpan.
On the old Chevy/GMC's, you just removed the oilpan bolts and dropped the pan.
The pickup screen has nothing to do with this topic.  The oil pressure sender unit is in question here and, as others have written, located at the left rear of the motor practically up against the firewall.  Watch:
As John McClane once said, "Welcome to the party, (newbie) Pal!"  You've done such a service to this forum by digging up a 6 year old post on a topic we were still learning about then, but has been beat to death since then.  Bite me.  Now back to your regularly scheduled programming . . . .
  • 2 months later...
  • 4 weeks later...
I replaced Oil Pressure Sensor on 06 Silverado 4.8L. Truck was reading about 40psi when starting-up but drops to about 30psi, but runs good. When I purchased the sensor it did not come with a filter, but some did. I YouTube some videos and some cleaned the filter and reused it. In some videos it showed how simple it was to reach the sensor without disassembling VLOM, so I chose this method. When I took out sensor I was trying to fish-out the filter with a pick, but could not feel the filter loosening nor could I see with an extendo mirror and light to see what was what. I was hoping to get a better oil pressure reading. So is this model Silverado have a fixed oil pressure filter or needing some other extractor tool. Need to know before I disassemble VLOM next Friday and get a better look. And I'll check oil pressure with a tester to reset oil gauge at the instrument panel which I should have done first...
I appreciate any insight.
iirc, the '06 didn't have a filter beneath the OP sensor. It was added later when AFM came into play
  • 3 months later...
I have 2011 Sierra, 5.3, 4x4, 140k miles, dealer oil changes with GM Dexos synthetic oil.  Noticed oil gauge reading 21-22 psi at 2000 rpms.  A few hours later got back in truck and the same thing, plus the check engine light came on.  Drove 50 miles to a dealer.  I don't know the codes but they said "oil sensor, oil pressure, maintenance".  They also said the oil sensor is where they start, at a price of $350.  Then they go on further if that doesn't solve the issue, including up to pistons and rings.
  • 2 months later...
  • Enthusiast
I had this issue.  Highway speed I noticed it at 21 psi.  Later the check engine light came on, dealer said it coded change oil pressure sensor.  I had an independent shop change it out.  He said the screen below it was clean.  So, after this was one I got 38-40psi on highway and about 30 idle.  I wasn't fully satisfied.  Some on this board said he had that issue once; changed oil & filter and has been driving it for years.  It didn't make sense to me but I did so.  This time instead of going to the dealer to do it I changed it myself.  Mobil-1 and a new filter for synthetic oil.  Highway pressure is now 40 or more.  But occasionally 39.  It idles at 30 (usually) but sometimes it idles at 21.  Why that would differ from 30 down to 21 I dont know (since the shop told me that screen under the sensor was clean as a whistle.
  • 1 month later...
New poster, actually not my truck. 🙂 While my son-in-law is out of town, I was going to install a starter for him. Driving the truck to my house there was no oil pressure. After watching @carnau video, I have a question on removing the wire connector.
The truck is 2012 5.3 LTZ 1500 4wd.
First, understandably everyone in their videos can only describes how to pull the clip off. I understand there are two operations. 1. you have to move a clip before you can press and remove the wire connection from the sensor. The video says to squeeze and lift up. Is that the first part? The clip comes up before pulling the wire connection? Here is a zoomed in.
Is the white the clip? Or do I have to lift the blue and squeeze the white?
I am not visualizing it yet.
LMGhyQ8JgPr0bqqrTQM1ZFWfISUElyVoOsTdjG6_E7KFq4NX9kYaeTgesLO82_-_XLzgqrKPIaaPIrVrInQhId0k95STsj-alWbOwtrtI5eDdruhf1QJf-itj7GLTk1LaqYNGge0bVZRECfAtz1TrIh2k2UzUUpHezof9cOS9hXVih5wZe5NV0rL0XedMThcpm9DQ7zjetnItTv5WjVLlZwj5YLh2i0NKT8Ko-nmpt-tFURUO2JSzJeGoIufdcG8_NELoXWS6gi__4NtiiysqmVK8HgcNLVEPOj7LnjKXOCmUpi_ghkRGkBzZNd3qLnBpKjSxrd16yL6kscxMLEOdnOWyYAraNvfxfqk-ChE7pCtN0x3HSiDU2S9XeRvaDx0CHyke3a26MKvFhgYWtAHXc1rjYYX3vn7VazI0q2vZqK9PA8-8WWb55E9z6ZcY8CZpemoXGb1THz6qCB1lfaVi4GdB0uzh-EJh-6itw4rXGutPio1ptJSZdWJcGP5k4pIprdjaEA6SkNlQTXc-FB814b1070t6tkgMeXIhla8EhXLryIyfGAxJ5GBGPkkEnpK8Y_C1rSdpyejfFlCsfn3NBkmSs8qcpiR69DX_xrWWnHVbfTCtSaXSCU9alVjN3HXGyxMXoAGxqO5EM9h9GJuUrB6IytIaM3Z071e6YcvUI208ceCUzvOnPjeYPbhuk4AQzUD8eV8QrXSiJB9SLjU_bfRxh1iVR8wItkt4ZEwzPKVwgvLAC4pEE-mp-zT_JpgEqQBnRNL_ALF4Y-j9iaPv0n_ZVQOs2nxBZWc_7k7614TmKqGRMG4KCwtzQOSPmo7X9uIwEOGy1IAwJj3Xm7uLGS4EBWg-8vK3yX8ZZjUR_J_vCEFFFeWa_2B03I4CLzNQIGZ5zMdQVto9Q=w704-h938-no?authuser=0
Since this is a 4wd, I have to climb into the engine bay and trying to get a mental picture since I am old and it is hard. 🙂
Edited by penright
Got it done last night. I going to add a couple of thing for anyone else who comes across this thread.
Here is someone who pulled off the intake. You don't have to and he said that, the only reason he did was for videoing. This help me in seeing how to disconnect the connector without being able to see it. 🙂   I linked the video at the spot after he has removed the intake.
Also, after getting it all installed, the gauged did not register at first. After double checking the connector and that not fixing it, I cleared the codes. The next time I started the gauge started working. Not sure if clearing code would have any effect, I just what I did. I almost wished I would have tried and cleared the code before swapping out the sensor.
And last, I found this meme that cracked me up after fighting the sensor behind the intake. 🙂
iy020XfVvUCUlYqTiAMi4rDsLdLJW9w44Yf3OeNy_ZLdkf7rqvdPv8ofNNKfd8XbHr70FDdIY909TAo6PLAgWnexVhRC1mwEiwVPMOmnHRinqkeGCMCDlOrb_fMJpZuI6hYS0iGbv4RW_qIiiLSzzg3TW5dBHgB003q-MxRVtTi-_TmRr3PyuRGzgAZiQgwag1XYjrfvX8IcMUsnvMoKjtSE8VtjFQ8xy3Aheq-aEkoDmGIPtVUgKA5saO2qwMNDbseqH0hzHWUQu4rLRqfy9qlsHWVfZAMHPK-kdXR8abduMTaSdsHGpIdnKsuNXMph5Y7O4SgifAaDHwTY8i7YGh4VtT6lr_2DtOXCxU9AeONfChNOray0B8S-g3ROYpM18k6oHAEURBjGEOlAefkSBYcwJsDgdI1MjaOK-M2KSyK-r9_i17HZmu6mP5jQdSYn9MLjGx_awSoHPOOA6h1WyV4iSFEve4Jye1aW5ms5T3rvBk-hm4ZJYWdzp39wklH9YkERWclNOoocpXwbz2T4TyIZMnCgCapwZrPneQXogxXQaaAef2UJtUuay79_SaOg86oE1uQcHoRpoCpby3i3U9vXxP2LQPcS-T3Kzjim-ImVYnqL-5S0XrIZ9To4SykrJroA_ll1NtgWMY1goKjsJCZ6UaUMYNpUpLGImbb1_iocmMPzO9lDiN3kKUGHRdwNvYD3Inx0kvTRY_idQEG_w-9T2sJcGSETaFh_TzY2JF1AhOSASONHST1WpdTMVheSKvf4AX7HaaaiTVXXWR4ABl37-8GpHkznU9lGZyBrnAH-pii8yks0JEgOVAHHDzdeWCY7kq5b9aiEjTb7pzXILps5ToJcdsgNQfovgP95lgQhxnHzT7hMToQgPJHS9HZr05zMKaasmJBbZQ=w1025-h938-no?authuser=0
  • 7 months later...
2005 Silverado WT 4.8. Recently purchased and restoring.
209K, I am at 40 PSI after additive and changing the oil with high mileage conventional oil. It was  lower.
Appreciate the information, but just another "thing" i should look at.
40 PSI is in the middle of the gauge and what I was taught, middle is good.
I have read about 60 PSI?
Would anyone know what the correct oil pressure should be ?
TIA
KC
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
