Here's a better picture after a fresh detail and in good light
Nice truck! Is that a level kit with 35s?
[quote name="jackedupZ71" post="1957167" and yes i hate these tires. will not stay balanced, ride horrible, and suck on gravels which i know most tires don't hold up. they were on my dmax before the fuel system crapped on me back in aug
What are the tires?
Just out of curiosity, why no duramax?
Isn't the duramax like a $10k option?
Picked her up two days ago.....a left over 2016 HD gasser. Was looking for a diesel, but got a good deal on the last gasser they had...so bought it. So far I love it.
Edited by stangd1909
Heres my 15 Double cab work in progress.
17x8.5 Sota wheels +6 offset
35x12.5x17 General Grabber X3
Warn bumper.
Leveled on stock keys but bilstein 5100s and suspension maxx UCAs and diff drop.
Warn bumper.
Sharp! I think those are the best looking aftermarket 17" rims that I've seen for our trucks. I know you're running a 12.50" wide tire, but how far do they stick outside the fenders?
Thanks. The wheels themselves are about perfectly flush. Just a few mm further than the common +18 size, but alot more room on the inside. With the 12.50 tires they sit just outside fender, 1 to 2 inches max. Ill grab a pic for you. I trimmed based on what i read on the forum but wasnt necessary after all. No rubbing at all
I took delivery 2 weeks ago:
Denali HD diesel, summit white, cocoa/dune, sunroof, off road suspension, trailering mirrors.
Last week, based on research on the forum here, I changed out the OEM boards to Amp steps, added an RC 2" leveling kit, changed the tires to Toyo 295/60R20 Open Country AT II's, and added black WeatherTech floor liners. I think I'm done for a while. Love the truck.
Sorry for the mediocre pictures - the weather has been frigid. I will post better pictures soon - the forecast looks good.
Wow! Beautiful truck Edited by dasimmon
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
