2 hours ago, Paulismydog said:
What size tires? Level kit?
Cooper ST Maxx 295/70R18
I turned the torsion bars up and added Cognito UCA and shock extenders.
Originally just turned the bars up a little and never rubbed just added the UCA's for longevity.
New here, with a new 2018 Sierra 3500HD. Bone stock for now, but always looking for ideas. I'd like to bring the front end up just a touch and add some bigger tires.
Yup, sounds like the rest of us...  :thumbs:
My 2015 in Rainforest Green Metallic. I love this color; it was only available for half of 2015. I need to get bigger tires on it.
I'm on instagram as @kurtkphoto
5c5936d701311_IGGRY_9152.thumb.jpg.a0e05acec4e609069b063f76f8952a6c.jpg5c5936de643ad_IGGRY_9205.thumb.jpg.f6671ef93353e66679026397354f06ba.jpg5c5936e7b5fe5_IGGRY_9215.thumb.jpg.9117732d20f4c16b668b3d4ff75c8577.jpg
0731d0077c220de14b66f6eb63aa2744.jpg95dc2361fef933335bff2d925c9568a0.jpgbca82cba09d510b39efae146e8591936.jpg
Getting the pro-pride hitch setup for my new ride.
6 hours ago, KMK454 said:
The unicorn?  I've never seen that color before.  Very nice.
Thanks! You could only get it on the 2015.5 HDs. It was also briefly available on the 1500s (2015), the Camaro (2015 Green Flash Edition), the 2014 Corvette (Lime Rock Green), and the 2014-2015 Cruze. In certain light, it can look almost black, but in the right light it pops nicely.
I’d say! Good looking pickup.
10 hours ago, wuznme said:
And you pulled right in and out? Right? Cool picture.
Edited by gearheadesw
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
