OK, this is my last hope. Summer is here. The a/c compressor went out in our 1995 C2500 Extcab Sierra pickup, 5.7L 350. We replaced the compressor, accumulator, condenser, hoses, o-rings, orifice tube, and the climate control. We have spent a lot of money and have been through hell with this thing. Well, the clutch is not turning on the brand new compressor!!! What the heck? Any help? PLEASE!!!
If the mechanicals have all been replaced with known good parts, it could be the control module. The module in my 97 is going bad, it now only has medium-high and off. It still works good enough so I haven't fixed it.
The clutch will not engage if it does not have enough freon in the system. Have you verified proper levels? Sounds like you are close, might take a 10 minute diagnosis from an AC Tech.
If you have checked or replaced all mechanicals (with new parts) and refrigerant. The only thing left IS power.
Agreed. I am no AC expert, but I've fixed three of these systems by replacing the low pressure cut-off switch on the accumulator. Pull the connector and jump the contacts with a wire. If the clutch engages, check your pressures with manifold gauges. If the numbers are good, replace the switch. If the refrigerant is low, there's your problem. Check for leaks and re-charge.
If you pull the connector and jump it with a wire and the clutch doesn't engage, you have a power issue.
I am getting a 96 going again. for those years something called a "thermocoupler" on brand new compressors might not be going right.
that goes on into 2003 apparently. Hit or miss.
if you still have your old compressor, could swap stuff around onto the new one.
you did not mention high side or low side valve. sometimes those pee a little leak to full drain.
After replacing all those parts did you have the system evacuated prior to refilling with refrigerant? If not you are going to have a lot of air in the system and that will wreck havoc on the system.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
