Is it safe to say you are rubbing quite a bit when you turn hard?
Yeah when I turn full lock to the right I rub. I think a half inch spacer could fix that
Close up pic
Do you have a close up of the rub? With a tire that wide on stockers, I would expect you rub at full lock in both directions. One way on the swaybar and one way on the UCAs.
Good looking tire though! I have a friend at work that just got some.
Only rub UCAs on both sides. I'll be getting spacers soon
Thanks. Those pictures are very helpful and highlight the limitation of tire width on stockers.
  • 5 weeks later...
I have 2" leveling kit with AAL, and 275-60-20 duratracs. I'm getting some rubbing on my UCA and am thinking about putting on some wheel spacers. I have mud flaps installed the wheel well that are about 1/4"-3/8" thick. If I put 1.5" wheel spacers on will I rub the mud flaps/ anywhere else? Open to suggestions to fix the problem and get a better stance.
After tons of forum stalking I finally pulled the trigger. Here's my 2017 All Terrain with a Zone 4.5" lift on 35x12.5r20 Cooper STT Pro tires and powder coated OEM All Terrain wheels. I can confirm there is no rubbing and no trimming was required (only had to remove the front lower valance)
Why thank you! Means a lot.
The ride isnt much different than stock to be honest! Still smooth and runs straight as an arrow. I had a gentlemen ride with me the other day and commented how how nice it rode. Said you wouldnt think it had a lift!
I would def suggest zone or bds (very similar). You wont be dissapointed with those lifts. Pay for what you get in my opinion.
I will post more pics tomorrow. I'm at work and only have a few in my email. Only other one I have at the moment.
I would just like to say that your truck is what I modeled mine after.
17 Elevation
Zone 4.5 general grabber x3 33-12.5 with1/2 spacer up front
Stock 20x9 +27 offset wheels no rubbing
17 Elevation
What did powder coating run ya?
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
