Lingenfelter Performance Eng. shows off 800hp Silverado at SEMA
John Goreham
11/03/2015
If you are at SEMA, check out the Lingenfelter booth at 20337. The company is showing off an 800 hp supercharged 2015 Silverado. In addition to the LT-based engine with direct injection the truck sports American Racing long-tube headers and a Lingenfelter exhaust system. Lingenfelter now offers power enhancement packages for GM trucks in 475, 550 or 800 horsepower versions. The company can install the engine modifications for you at one of its two locations, and also delivers crate engines.
Our thanks to forum moderator RyanbabZ71 for the heads up and the great image.
Wow! 800 horsepower, that would be awesome to drive. Does anybody know what the 800hp upgrade cost? Just curious.
The 550hp package for 6.2L is $9k, so I would guess between $15-20k depending on what parts are needed to achieve 800hp reliably.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
