2016 Backup Camera
Unrelated...but is your truck black or Iridium Gray? Looks great in the pic!
It is Iridium. and thanks!
  • Replies 32
I cant tell a difference between the camera that was on my 14 to the camera on my 16.....both were just fine, Im not watching a blu ray just tryin not to hit anyone or thing.....just sayin
My camera works, and is functional, but maybe I (rightfully, wrongfully?) expect the picture quality to be as good as the '14 Equinox my wife has, the '14 Malibu my grandma has and the '16 Cruze or even the '13 Yukon.
Looks like I'm not the only one with a "grainy" camera though...
What size screen do those other vehicles have in them? Same resolution camera on a smaller screen could look better but not actually be better.
I'm in the camp that is fine with the camera as-is. I also use it to hook up trailers and from day 1 I have lined up hitch ball with coupler every time on 2 different trailers. I have not had to get back into truck any to re-position.
Good point!
Had the camera on an 11 2500, but not the navi, so the camera view was on the rearview mirror. Worked fine for when backing up when parking, but was very hard to use for trailer hook ups.
I had the exact same mylink radio my truck has in my 2013 Traverse and the reverse camera in that thing was crystal clear day or night.
My lawn is always blue in the truck ha ha.
The camera was angled in the Traverse not sure if that made a difference or it's just a better camera.
honestly, I doubt it is the actual camera itself but more of the quality of the screen you are watching it on...
No, not even close. The only similarity there is that they said MyLink when you turned them on
That's also what I heard from one of the aftermarket camera vendors, says the factory screen is not the greatest resolution.
I don't get what the complaint is? You want a 4K UHD TV for a backup camera? Is there something you're not able to see with the current one? Do you frequently run into things that are hard to see? I agree that the picture isn't 1080p, but I think it's more than adequate for it's intended purpose, no?
I couldn't agree MORE with this. Everyone is griping about the quality. It's to help you back up, not watch the latest Blu-Ray in 4k UHD!
If I drive my truck 100,000 miles, how many of those miles will be in reverse? 500? Driven 100' at a time (that's the length of my driveway)?
I live in the -WOODS-, no street lights, and have only a couple of small lights on the garage. I have NO complaints about how well the camera works to back up the entire length of my driveway in the pitch black.
So people shouldn't complain about vibrating trucks? It get's them from A to B still, right? 100,000 miles later, it's still getting you from A to B, so why worry?
In other words, people shouldn't care about quality control on a $40,000 truck is half ass? Should have bought the $70,000 version, right?
Anyway, for what it's worth, my truck's screen is much clearer and has a higher pixel density than the wife's Equinox. Also, it's a difference in 1" screen size. The difference is marginal. It seems pretty clear that I'm not the only one out there that got a crappy lens for the backup camera. Is the camera still functional? Absolutely, but excuse me for being concerned about the lower quality parts that go into a vehicle that easily costs 2x as much as most cars on the road.
What in the WORLD are you talking about? How does image quality of the backup camera have anything at ALL to do with quality control?
    • After my recent rear end bumper damage, body shop has made the repairs and included a new OEM receiver hitch.  I started thinking about how it was tightened...to specs or by hand or ??.  I called the body shop and asked and they said it was tightened by an impact gun.  I said I wanted it tightened to OEM specs.  They said no problem, bring it to shop today and they will torque to specs, which they say is 74 ft/lbs.   A couple of questions,,,,   1.  Should new bolts have been used?  If so, how many are there (bill shows one and four (I assume different areas of receiver).   2.,  Since they torqued with impact gun and now are going to probably loosen and then torque to spces, will that damage/stretch the bolts?   3.  If old bolts were reused (truck has 9000 miles), is that a problem?   4.  Any other things iI may have missed with regard to receiver replacement?   NOTE:  Attached are the receiver hitch specs from my digital OEM service manual.  It shows to horizontal mounting bolts and four vertically mounted bolts.  Other sections of manual reference eight vertical bolts.   Thanks!
    • Is this supposed to be in English?  "close to 100 fake, new brake pads sign on the dash board"     Pull the wheels off.  Check the brake pad thickness.  Check the sensors out.  You could have good pads and the sensors aren't in to the worn out position, but have an electrical fault with the sensor or the plug wiring to the sensor.
    • Gas or diesel???????????   You did not indicate.  Your topic just says "2022 10L80".
    • Tomorrow I go in for my third joint replacement in jus a little over a year year!  I am not worried about the surgery but I am a little annoyed about going through the recovery process again!  I keep my frustrations to myself as I do appreciate that I am truly lucky.  Knee, hip, and shoulder replacements are routine, safe and improve mobility.  The next couple of days will be slow but every day following will see steady improvement in my mobility.
    • Practical Application ISO 4406   I think this oil cleanliness thing is going to boil down to ones personal resolve. The information is there but applying it I believe will test your commitment to the machine. Implementation would involve building or buying a prefilter or purchase of an "ISOCLEAN" oil. Then installing a single digit micron bypass system. A good deal of testing and about 99.9% of you are saying at that point....yea.....not my cuppa tea. So what can you do?    You already did the first step. Get educated and leave the bias at the door. Be aware of the its, cleanliness, importance.    Do your own work if you can. Keep the equipment clean. Not just your funnel but the engine bay. Use sealed containers. Think it through.    I believe you will find, as I did, that the tightest absolute full flow filters (Beta 200) will be around 20 micron. That will yield on average a Beta 75 of 10-15 micron. They are few in number by brand and price point. Loose filters are a dime a dozen and even the best brands have lines of loose filters. Some cleverly marketed as "Extended Service". Others will market flow over efficiency. But I think the take away once informed is that the extra cost of the best offered is a bargain. There are cheaper filters with good efficiency that are equal in performance to niche brands with big prices. Your Quick Lube is about a 40 micron unit. This is where your dealer is a plus. the AC-Delco filter is a good step up from those places. Even better if you specify the UPF line.    Be skeptical of marketing. Buying an oil that is made from GTL advertised as the cleanest base oil is using a truth to support a lie. While GTL's are made from debris free gas the processing equipment and post handling is just like any other oil. It also ignores the fact that PAO's and Esters are also gas in origin. Any private prescreening testing you would do, and some have done, would yield a result only good for the batch you tested. AMSOIL and Schaeffer's have built a reputation for paying attention to this detail.    Context. Cold starts account for at least 75%, or more, of an engines wear. But of the remaining 25% ish, over 80% is caused by particle count. Now where do we find high milage motors that use this type of information efficiently? OTR trucking!      Now, anyone want to build a prefilter or off line cleaning system anyway?
