Hey guys,
I posted in the giant thread about my fix but I'm sure it's already gotten lost. I think this is important to at least have floating somewhere for someone to search.
Symptoms: At 60-70mph I was experiencing a severe shake/vibration. I could usually push out of it at 70+ but it was still noticeable. It was like clock work as soon as I hit up around 60mph.
Solution: I got my truck fully inspected before purchase and they noted the vibration. Mechanic showed me a dent in the drive shaft and general wear on the shaft. His recommendation was to replace it. I ordered the part online. The new shaft came fully assembled with new Ujoints and the yoke to slide in. Installation was very easy. I have driven 100 miles since installation and I have ZERO vibration. I hit 60mph and it is very smooth. So the culprit could be the shaft the ujoint or the yoke. Once again this fix worked for me and it may not be the same issue on your truck but I had pretty bad vibrations and they are GONE.
Good luck!!
*NOTE* I have no warranty so that is why I attempted a fix on my own. I'm sure this problem will still crop up as peoples warranty starts to expire.
Edited by Bowtie619
Have you taken the truck to 72 mph or higher? If so did it vibrate then? Most people with the vibration problem (including myself) do not have vibes below 70 mph.
I have taken it up to 85 with no issues. Cruise at about 80mph to multiple destination with no issues. It's a night and day comparison. At this point the vibration is not partially but completely gone. I've only gone about 100 miles so there is still a chance it could come back but I'm willing to bet there was an issue with the original Ujoints or yoke. Also, when I pulled the yoke out it looked pretty dry. The new shaft had a ton of lubricant in it. Not sure if that could have been an issue as well.
What ratio is the rear end in your truck? 3.42?
There has been quite a few people who have had their driveshaft replaced and it did nothing to cure the vibes. I think you just had a bent drive shaft that caused vibes and the new one fixed it. You said you were having severe vibes between 60 and 70 mph, almost all the complaints on vibes are either above 70 mph or below 45 mph.
I agree, but did they replace only the shaft? Or were the Ubolts and yoke also replaced? Just something to consider. The dent was so small I don't feel like it could have affected the overall spin of the shaft but I could be wrong. Like I said, there is no definite solution for everyone but this 100% fixed my problem. The part was about 350$, with I think a 30% restocking fee on returns. Might be worth the risk to some people who don't have any other options at this point.
I'm not sure, is there somewhere I can check this?
would you say that your vibration was slight at 60 peaked at 65 and reduced to 70 and then basically went away after 70?
I wouldn't say it went away at 70+, it felt more like it was pulsating slowly. The rest would be a good description though.
This confirms something for me, my suspicion has been that these truck resonate at 39 Hz which means even slight disturbances can cause vibration issues. Which for tire speed peaks at about 75 mph. or 3 times the rotational speed of the tire. Because the rear end ratio is 3.42 in your truck the drive line angular velocity is approximately 39Hz at 65 mph. Confirms the problem is resonance and the body mounts like to transmit vibrations in the 39 hz region. Like you said the dent looked so minor you wouldn't think it would cause issues but if you have a resonance situation even something minor makes it way through. Thanks for the info
  • Like 5
I'm no engineer but that doesn't sound like there's an easy fix for that?
Redesign of the body mounts, which would require more crash testing and expensive qualifications. Makes me wonder if the reason some trucks vibrate and most don't is the batch of rubber the mounts are made from. I've considered purchasing a new set but you'd be in it a 1000 dollars to do the 6 cab mounts. They're a hydraulic shear mount which was patented in 2011 by vibracoustics north america which is owned by Trelleborg, and according to their website they make just about every body mount for every manufacture so I can't see why the would only have issues with this particular truck but who knows. I'm working on a mount to cancel out that frequency that will replace the pucks used for my 1.5" body lift, but the spring rate of rubber is tricky and it's dependent upon the weight of the cab so I'm just throwing a wild ass guess at what that number is plus you have to account for a varying mass from 200 - 1000 lbs depending on passengers. Going to be some trial and error I'm sure.
I totally agree with all of this.
I wonder how the previous GMT-900 body mounts compare dimensionally. Will they fit?
That's a negative not without some serious adaptation. This is an avenue I'm currently looking into though. at least for the two rear cab mounts. When GM had a problem with frame beaming on the HD they released a redesigned cab mount to fix the issue. Because I have the body lift I can fit the GMT900 cab mount which by the way is the same mount still used on the current production HD platform which doesn't vibrate. The major difference is the new shear mounts bolt to the frame with 2 ears that attach to outer isolator, the interior isolator that carries the mount bolt just passes through a hole in the perch and doesn't actually sandwich either side of the perch see the patent link below. My thought without measuring the through hole on the perch is that it is too big and the lower mounting isolator from the GMT 900 will having nothing to seat against see the other link below. But I think there is enough room to fab an adapter plate that can use the 2 existing holes for the shear mount to bolt into place and carry the GMT900 mount. I thought about giving this a try before replacing all the lift pucks with something else. Below are the two links one that shows how the GMT900 mount works and the other is the patent for shear style mount which is what is currently underneath the K2XX 1500's. If you look up part # 25994881 on a gm parts website it shows it as being the current mount used on 2015 2500 and 3500 pickups and being the replacement mount on the GMT900 trucks as well.
http://www.gmtruckcentral.com/articles/bodymounts.html
http://www.google.com/patents/US7389977
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
