Is there a definite period of time where these trucks were affected? I have a 2016 that's about a year and a few months old and has 28k. No issues so far but I really don't want to have to deal with my ac dying.
Hello guys, I have a 2016 GMC Sierra crew cab. I was just wondering when the bracket that is suppose to fix these leaks was added? Do I need to see about adding one to my truck?
Knightfall,
You are going to hit the issue, it might be in a few days, weeks, or a few years from now. My 2016 hit it less than a year with about 1000 miles on it. The good thing for you is you have time until your warranty expires. GM MUST issue a recall. If they don't, the AGs of multiple states will force them to issue one.
Soectaculous, thanks for the advice. My co-worker and I were messing with our subs and ended up opening the hoods. I Remembered what you suggested and I checked...bb015ce54b07272be63494b3d39b0152.jpg514f3be1cadc4fefbdae367249b8958f.jpg8713fe4b86c4a27458a677a419850e98.jpg6182cec622a2b63e06b7e3144bba9b96.jpg
Time to start shopping for a new condenser. :/
Edited by mois93da
And here's roof that it is a leak. I had put UV dye in the system the first time I recharged it. 8bb9307aace93f4c92471b84f28b5b31.jpg
Yep. Welcome to the club.
Ok i looked my driver side condenser is wet. I rarely use ac. Dealer dident even look just oredered me a new condenser. Ac isent horrid yet so hopefully it holds for summer. Said no aftermarket parts avail now here in MI. so now the wait.
have you checked Amazon?
This is what my truck has been doing for the past month. I refuse to drive it with no AC. It will be sitting like this for probably another 2-3 months until the re-designed AC condenser comes in. By then it'll be fall so I won't care about AC.
What does the accumulator/dryer look like on these trucks? Is there an orifice tube? I'm just trying to get the parts together for the condenser replacement. Also, how much oil do I have to add to the system?
You'll probably be surprised as I was, but the dryer is integrated directly into the condenser. It's the cylindrical header on the driver's side. New condenser already has fresh dessicant installed from factory.
As for oil I can't recall, but it's tiny. Like 3.4oz or something.
It's not a precise science. Put 2 oz in for a new condenser and you'll be fine. Another 1.5 oz for new lines.
The orifice is in the block where the lines attach at the firewall.
Edited by spurshot
    • 3.19 @ Kroger’s in Montgomery Tx
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
