Tailgate LightBar Wiring?
MoonDogg
Anyone got the color's and location of all the proper wires I need to tap into for the running, brake, right & left turn and reverse? Thanks.
Depends which tailgate lights. I have seen the wired right into the taillight harness which makes the most sense. It is pretty obvious which is which when you pull your tail light off which is simple. Some people just use the trailering connector.
Thanks for the reply... and the one I have also has the 4 pin connector and I could hook it that way.. (and I might) but I was thinking about hard wiring the whole thing. so the plug is not hanging out..
I used this simple T connector and just hard wired the reverse wire off of the connector! This way the plug and all the wiring is behind the bumper.
CURT 55384 T-Connector https://www.amazon.com/dp/B0009FJ38Q/ref=cm_sw_r_cp_api_PmM7xb2XW4K6W
Thanks!! I like this solution. I currently have it wired to the flat four in the front with a pigtail extension going under the license plate. It don't look to bad.. but I do like this options... But the t-Harnes is more than I paid for the light bar :P I leave it like I got it far awhile see how I like it...
