looks good. How do you like your OPT7 HID / Led's ? Would you do it again ?
output and pattern of the HI/LOW HIDs is great... i am having some random issues of one low beam not firing on every once in awhile.. sometimes pass side.. sometimes driver side... BRAND NEW BULBS... harness and capacitors hooked up...
the ballasts, harness and capacitors are pushing 2 years old... not sure if thats the reason or not... but i have the new Opt7 FluxBeam X LEDs that will be at my door tomorrow that I am going to try in the low beams and see how they are
Which fuse did you use?
there is a 10amp misc ignition fuse under hood... cant remember off top of my head... but i will try to get a pic of it ...
PM me if you are interested and ill send the pic directly to you
2014 Silverado.... fuse #39 "Misc Ign" 10amp under the hood
this pic looking at fuse box standing by left front tire
I have the same set up for my headlights. Great lights, the fans can get loud sometimes but not to the point where you hear it that much in the truck, they have horrible horrible customer service. One light went out while warranties and it took a month to get a replacement.
ON your OPT7 lights , any problem putting the dusk cover back on ????
Black vinyl
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
Edited by wildchevys
  • Like 8
Yes it’s tough, you have to pack all the cords inside before you put the cover on but it will fit.
A co-worker and I were just discussing the OPT7 FluxBeam X LEDs, I'm going to get some soon. He has them on his Explorer and both of his motorcycles, and loves them.
Here's a $1 Mod I found.......but think I would use 3M vinyl sticker ....cleaner and could be removed....
Thats a cool idea. Plastidip or vinyl would work great for this. Hmm...
I used plasti dip just because I couldn't find a good vinyl that was just red and not carbon fiber looking.
22254800 10211859080965472 2197115083207342625 O
22218547 10211859081405483 2408556649631852962 O
Made a mesh insert using black steel mesh I found in the gutter section at Lowes. It takes 3 pieces for about $12 total. I wasn't a fan of the large openings and when I took the grill off I had a nice pile of big bugs and 1 bird at the bottom of the radiator.
Once you get the grill off their are 6 plastic pins to get the air shroud off the back of the grill. I cut to fit and used .032 safety wire. I drilled some holes in the back to get a secure point an that might turn off some people.
I just put the FluxBeam X in my low beams (H11).... very impressed so far!!! ZERO light scatter and I have halogen reflectors
Has anyone tried OPT7 HID kits? Specifically the BOLT AC Slim series.
I had the Opt7 Canbus on my 14 Silverado... had some intermittent issues with only 1 light firing on the low beams (it is a set i have been using for about a year on another vehicle... so could be ballasts/relay going bad)... great light output from them though.....
low beams (Opt7 Canbus 5000k)
high/low beams (both Opt7 Canbus 5000k)
both low beam pics are from exact same location... so you can compare HID vs LED
Edited by caskey_b
I had to paint my grill after I used the 3m adhesive remover, stained my grill white
Painted it all black and looked plan so I decided to try something crazy for a bit.a92d1ca03d65ae76fa8f7ae6c20a405d.jpg65b78c507713042899efc21464fc0ced.jpg45ad2903dcc4291be69f72f2d81b3a47.jpg
I like it! :)
-S
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
