Hey all,
I recently purchased a couple shallow mount subs, a subthump box, and an amp/wiring kit for my 2015 GMC Sierra SLE. I also purchased this line output converter to get the signal to the amp from the stock wiring. I searched for "line output converter" and literally nothing came up on the forum, so i'm curious if anyone knows the easiest place to tap into to get the subwoofer signal to the amp? I'd greatly appreciate any help!
My truck is a 2015 GMC Sierra SLE, does NOT have the Bose factory system.
PAC LP7-2: http://www.pac-audio.com/productDetails.aspx?ProductId=1188
Gear i'm adding:
2x Rockford Fosgate P3SD2-12
1x Power Acoustik EG1-2500D -- wired to 2 ohms, about 800w RMS total
subthump dual 12" box w/ amp rack space
Thanks!
Captain
Edited by CaptainMcFunk
Anyone have any ideas on this? I scanned a thread yesterday for a long time and came up with one person that stated these were the wires to tap into, but no one said anything else -- Anyone have a picture of the harness i'm looking for to tap into?
For non-Bose, you can tap the rear speaker wires in the B Pillar before they go thru the harness to the rear doors. They are twisted pairs.
Left Rear Speaker (+) green // (-) green/black
Right Rear Speaker (+) white // (-) blue/black
If you have the bose upgrade you tap into the amp behind the rear seat.
I appreciate the response, but I included it in the original request that I dont have the Bose system, as that seems to make a huge difference in where you tap in. As i've been going along today preparing for this install, here is other info i've gathered:
ITEM WIRE COLOR LOCATION
Left Front Speaker (+/-) // blue - brown/blue // radio, green 16 pin plug, pins 1 - 9
Right Front Speaker (+/-) // yellow - yellow/black // radio, green 16 pin plug, pins 2 - 10
Left Rear Speaker (+/-) // green - green/black // radio, green 16 pin plug, pins 3 - 11
Right Rear Speaker (+/-) // white - blue/black // radio, green 16 pin plug, pins 4 - 12
I was hoping to just tap in at one of the plugs in or near the BCM, which may be possible, I just don't know. A tip that I got is to pull the B-Pillar panel (between front & rear doors), pull back or cut the tape on the wires going into the rear door to look for the speaker wires. It should be the ONLY TWISTED PAIR in the bundle. I may go this route since I don't know if there is an amp after the green 16 pin plug at the radio.
Forgot to mention which power source I used for the amp's remote on....
If you look under the driver's side dash between the brake pedal and parking brake, you'll see the fuse/relay box (it's about 6" x 10" and has a smooth black plastic cover, just like on the GMT-900's). Pry the clasps on each side to remove. On my SLT there are three main banks, left to right, with the first being unoccupied (see attached pic). The slots within first bank are labeled 1-20, though only 11 actually have male connectors. I used my tester to determine the following: #'s 7 & 17 are constant 12v power [always on], #'s 10 & 11 are grounds, and #8 is the RAP [retained accessory power] ignition signal wire (again, see attached pic)
For newbies, RAP powers on with the key rotated to the first position and remains on until the ignition is turned completely off AND the driver's door is opened, just like the factory radio.
Have you tried searching LOC? There is a youtube video of a guy who put it behind the radio inside the dash. You should use the font speakers since since the rears are quieter, the only down side is the front left speaker is the one that makes your blinker sound and door ding. I've yet to install an amp/subs but thats the information I found so far.
Edited by Donolie
If you'd like to clean up and have full amperage for other mods I built oem supplier (Delphi) harnesses to tap that x7 port.
$45 plus shipping. GM parts are $68 and not pinned
To be clear, I but from who gm buys. I meant if you purchase through gm, that would be the price and the trim would be blue. It's still a Delphi connector
  • 2 years later...
  • 3 months later...
So I'm doing this as well and I find the twisted green and green black wires on the drivers side but no white blue/black wires . Would they be on the passenger side ?
Sent from my SM-G975U using Tapatalk
I just did the LLJ harness and it was easy install, took a couple of weeks to get the harness as they were behind, but communicated well. I plan on getting another adapter for the other truck.
  • 5 months later...
Do you know if it's the same on 2017 Silverado LS double cab No Bose speakers??
  • 2 years later...
Why can't you tap into the speaker wires in the B pillar with the bose. I have a line converter that says it can handle a amplified signal up to 400 watts.
Idk but I've been wondering the same thing about my 2013 ltz with Bose and after many unsuccessful searches I think I'm just gonna try it and see. I've got the Kenwood amp and subs tapped into the factory sub wires at the amp and it sounds alright and gets loud but leaves something to be desired I guess. I had these same subs and amp installed in an old Dakota with a basic alpine half din CD player with an old iPod cord plugged in the back and it sounded amazing.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
