Factory battery - 30 months 57k
  • 1 year later...
  • Replies 50
Replaced mine today. 61,000 miles on a 2015 Silverado. I bought the truck in July '15.
Battery life average is 7 years depending on use and abuse.  Like anything Some will last 15 years and some will die on delivery. Luck of the draw, My 07 Cobalt's battery died last summer and my wife's 08 G6 died last month. So 9 to 10 years on OEM batteries
Looks.like Optima does not yet make an H7 or a 94R equivalent.  I've been using red tops in my performance cars and yellow tops in my Jeeps and trucks for over 20 years.  All have been great batteries.  I replaced the oe battery in my 08 caddy at 6 years old just because I felt it was beyond the age I could trust it.  That car had electric door handles, so dead battery means the doors won't open.
I have no idea how long the battery in my 15 will last, but it seems fine now.  Looks like I need to plan to replace it soon though.  Maybe it will last long enough for Optima to make a yellow top battery for it?  Not holding my breath.
I had to replace the battery in my '07 after about 2.5 years, and 30,000 miles.
I just replaced it winter of 2016, after another 8 years and 75,000 miles.  Then I traded it a few months later :sigh:
I'm already mentally preparing for the battery to die on my truck in another year or so :rolleyes:
I think batteries are just made cheaper these days.  The battery in my 2002 lasted over 10 years before I had to replace it.  I have a 2006 motorcycle that had its first replacement battery last year.  On the other hand my 2012 motorcycle has had two batteries in the last 6 years.
I have a Napa on my solar charging system that is over 12 years old, the Dodge battery it's paired with is 15 years old...the mate to the Dodge battery (diesels have two) is in my generator...
I'm on the original battery in my 2012 with 130k...
The 2007 we have at the shop with 188k miles just got its first battery last summer...
Steve
2012 2500hd 6.0l
My truck is almost 5 years old now with 40,000 miles. I guess my battery might die any minute ;). At least the battery looks easy to replace :).
You if this happens the cap over the keyhole slides off and you can open the door with the key. Just FYI
more Heat = shorter life. My 02 F150 battery lasted 9 years. This 2017 runs much hotter under the hood than any vehicle i've owned, High temp T-Stat means hotter and active shutters means less fresh air on the highway to take the heat away.
32k on 33 months. Yes, the weather in Florida took a beating on mines. Pick up the three year warranty
This spring Optima is going to release a DIN sized YellowTop (H7) - there was a press release last fall and I think they mention it on their website.
That would be great, I hope mine holds out until it's available.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
