Please Help. We're working on a 2001 Chevy Silverado 2500HD.It was stuck in limp mode. We first got the P0783-85 codes, so we replaced both shift solenoids, as well as the wiring harness. Still shot the same codes and was stuck in limp mode. So we replaced the transmission. Still didn't work. Now it's pulling up P1860 and both shift solenoid again. Also I realized it was shooting these codes before I even put it in gear. And that's what makes me think it's the ignition switch. Any help at all will be greatly appreciated and save my sanity.
Edited by PedroJ
Starting with the P0783 code:
Potential causes of a P0783 code include:
  • 3-4 shift solenoid failure
  • Electrical short to power - pinched wires
  • Electrical short to ground - pinched wires
  • Open in power or ground circuit wiring - disconnected or loose connections
  • TCM or PCM internal failure
Potential causes of a P0785 transmission code may include:
  • Damaged or defective shift timing solenoid
  • Dirty Automatic Transmission Fluid (ATF)
  • Low ATF
  • Obstruction in ATF passages
  • Broken or damaged wiring harness
  • TCM issue
  • ECM issue
  • Pin/connector problem (corrosion, melting, broken lock tab etc.)
P1860 CHEVROLET - TCC PWM Solenoid Circuit Electrical
Possible causes
  • Faulty Torque Converter Clutch Pulse Width Modulation (TCC PWM) Solenoid
  • Torque Converter Clutch Pulse Width Modulation (TCC PWM) Solenoid harness is open or shorted
  • Torque Converter Clutch Pulse Width Modulation (TCC PWM) Solenoid circuit poor electrical connection
Looking at all the codes, ...and their "commonality" I'd look at "all" the electrical connections going in and leaving the trans for corrosion, rust, broken pins. See if the wire harness is pinched / sliced back to the ECM. Another biggie, I need you to check both sides of every fuse in this truck. That includes any power distribution fuses. If any fuse is blown, that is a short to ground.
First, clear all codes, turn key on to get vehicle power, what codes returned???
No codes, start motor and let warm up. What codes now???
Report what codes you have at this point not putting the truck into any gear.
Now wiggle any wire harness from trans back to the ECM truck power on, motor not running. Check for new codes. Look for possible shorts to ground or severed wires.
You said you replaced the wire harness, ...what wire harness??? Wire harness for this ECM to trans is over $1000. I'm confused???
It is not an ignition switch issue, I'm leaning towards a short to ground or open circuit at a connector.
Yeah, it looks like an electric and/or tcm issue. I wouldn't expect a problem with the ignition switch/wiring harness to throw these codes...
I know this is unlikely, but it is theoretically possible that you got two transmissions with the same internal problems. If you completely discount that as a possibility, then its possible that you may never find the problem.
Barring aftermarket electrical equipment (remote start, security, etc) malfunctioning, I'd put money on failing ignition switch. Very common problem on 99-02 trucks. There's even a TSB on it.
carkhz316,
TSB's are everything in a repair. Would save a lot of time and grief.
Can you list the TSB for PedroJ ?
carkhz316,
Absolutely. I have experienced this myself when I was in Tech School. A friend brought his 99 Silverado 2500 (which I ended up owning some time later) to a local GM dealer. They couldn't figure it out. Told him BCM. Wrong. My instructor noted the TSB which the truck was showing the exact symptoms of. One new ignition switch later, and it was solved. I've since fixed this on a few other vehicles. Anyway, this is just a copy paste:
TSB# 01-07-30-002D
Malfunction Indicator Lamp On, Transmission Stuck in Second or Third Gear, Instrument Cluster Inoperative.
04-05 Rainier
99-00 Escalade
02-05 Escalade and EXT
03-05 ESV
97-99 Chevy/GMC Full Size; Pickup, Suburban, Tahoe (Yukon) (Old Style)
97-05 Blazer (Jimmy), (Bravada), Corvette, Express (Savana), S10 (Sanoma)
99-05 Silverado (Serria) (New Style)
00-05 Suburban, Tahoe, Yukon, Yukon XL
02-05 Avalanche, Trailblazer, EXT, Envoy, XL, XUV
04-05 Colorado/ Canyon
03-05 H2
04-05 GTO
With 4L60-E, 4L65-E, 4L80-E or 4L85-E
Condition: One or more of the following problems:
- The Malfunction Indicator Lamp is on.
- The transmission is defaulted to second gear (4L80/85-E).
- The transmission is defaulted to third gear (4L60/65-E).
- The instrument cluster is inoperative.
Possible DTC’s: P0720, P0753, P0758, P0785, P0787, P0973, P0976, P1860, P2761, P2764, and P2769 may be set depending on the vehicle.
Cause: The most likely cause of this condition may be a loss of voltage to the transmission on circuit 1020. This loss of power may be caused by an open in the ignition switch. This condition my also be the result of an incorrect installation of an aftermarket electronic device such as a remote starter or alarm system.
Correction: With the ignition switch in the RUN position, test for battery voltage at the appropriate fuse listed below.
97 S/T Trans 24
98-05 S/T Cluster 11
02-05 S/T Ignition 0
97-00 C/K(Old) Trans 20
99-05 C/K(New) Ignition 0
97-02 G-Van Trans 20
03-05 G, H-Van Ignition 0
03-05 H2 Ignition 0
04-05 GTO Auto Trans
97-04 Corvette Enging 1
05 Corvette ACC/TCM
04-05 Colorado/Canyon Trans
If the battery voltage is present at the fuse, inspect the ignition voltage circuit between the fuse and the transmission for possible opens. If the battery voltage is not present at the fuse, replace the ignition switch.
If the vehicle is equipped with an aftermarket electronic device and the DTC’s are being set when the device is being used, verify that the appropriate fuse listed above is being supplied battery voltage during operation. If voltage is not present at this fuse, these DTC’s will be set due to lack of voltage at the solenoids. This condition is most likely to occur with an incorrectly installed remote starting system. If this is the case, refer the customer to the installer of they system for corrections.
Edited by carkhz316
Sorry it took me so long to reply I've been working on some other vehicles. Since I posted last I tried unplugging the pcm for an hour, and after I plugged it in in It went into a lower gear just for a while and I could manually shift from that to 3rd. Im not sure if it was 2nd or 1st. Also after I clear the codes and restart the engine, the codes are back before I even put it in gear. I pulled up the data display on the transmission and all three circuits say there open/short to ground. I also replaced the ignition switch and no luck. Another thing the cluster is working fine before and after the new ignition switch. I'm about to go over the harness from tranny to pcm. I also recently acquired a volt meter so I will be checking voltage on each wire. I think someone posted which ones to check and what to check for, but if not could someone point me in the right direction. Thanks to everyone for all the support. You are all great and amazing people.
Your next area will be the wiring / connectors "to" the transmission.
If there is "any" rust, corrosion, foreign material replace the pins (if you can), or replace the trans connectors as required. Look for broken / pulled out wires at connectors.
Disconnect then reconnect one transmission connector at a time to see if that changed anything.
Stating that you changed 2 transmissions, ...and the problem is still there, .....tells me the problem is with the circuits leading to and from the transmission. Broken wire, poor electrical connection, backed out pin, blown fuse or a failed electrical component that is controlling the transmission.
Look at the commonality connection of all the problems, ....that will be your reference point of repair.
Edited by Motor City Rick
So I tested the E circuit wire at the transmission plug and it's only got 9.62 volts. Plus I inspected the wiring harness all the way from the tranny to the tcm no splits, breaks or exposed wired any where.
Edited by PedroJ
Go to" Ign0" fuse (10 amp). Measure the available voltage on both sides of that fuse. Is it the same as battery voltage? If yes, move on. If no, find high resistance back to the battery
Now disconnect the ECM (ignition off), to keep things simple, test all pink wires for battery voltage on the ECM connectors.
If any pink wire has no voltage, go check both sides of the fuses in the power distribution center (under the hood) and the fuse panel in the dash, check for blown fuse(s).
Now I need you to focus on checking for battery voltage with pin # 75 (pink wire on ECM connector), that feeds the "E" pin down by the transmission.
Is there battery voltage? If yes, that is good, now remove the trans connector with terminal "E" and measure for battery voltage to ground. Is there battery voltage?
If yes, available electrical power (battery voltage) is available to the transmission.
If no, high resistance issue back to "Ign0" fuse.
Check pin # 63 also (pink wire) on ECM connector. Is there battery voltage? If yes, move to terminal "E" on the trans connector with the trans connector disconnected. Measure voltage to ground, is there battery voltage???
If yes, available electrical power is available to the transmission.
If no, high resistance is in the circuit back to the power junction point.
  • 2 years later...
Hey guys, I'm hunting the same issue.  Stuck in limp mode.  Have inspected entire harness from trans to PMC.  One thing that sticks out is two pink wires going to trans 1 has good voltage with test light 2 has lower voltage (light is much dimmer).  When I turn ignition on one wire loses power completely.  So the question is should both stay hot or not?  Can I send temp power to the dead wire to see if it come out of limp mode?  05' silverado 5.3 4x4 4L60e.  Thanks in advance.
  • 4 months later...
I have an ‘04 trailblazer Ext with the PO785 code but when I clear the code with my OBD11 tester it works ok until I drive for a while then it comes back when I get to about 35 mph
    • Yes they are a good addition to make the truck more visible.   I have the OE ones in the lower front corners. I added some amber fogs to the bumper from Diode Dynamics SS6 model and wired them to my upfitter switches.
    • I had an issue with a new 1985 Z-28 some years ago. The 4WDB's were less than adequate when purchased IMO.  I had taken it in for small warranty services and asked them on three occasions to check them. Each time is was "could not duplicate on the service ticket. The warranty ran out about a month after my last visit and had to take it back for warranty rework. I again complained about the brakes. Well, low and behold, this time they determined the rear calipers were sticking and gave me a quote to repair. They had records as well as O had receipts of each time complained about the brakes while still under warranty. My dad was a life long body shop owner and told me to keep my cool and tell them that I wanted to speak to the GM Regional District Manager. The service manager disappeared for a few minutes, came back and told me they would replace the calipers free of charge.
    • Towing a 2022 Lance 24 ft travel trailer with our 2021 GMC Sierra 2500HD, gas.  Loaded, trailer is about 6,000 lb.  We get up to 10 mpg at 55 mpg, such as I-5.  Pleased with the combination.
    • I decided to give it a shot and see what sort of a gong show it would be to a pan drop themed oil change on my 2025 gas truck with the 10 speed. All indications I had seen so far was that there was no way that pan was coming out of there due to the cross over exhaust pipe not allowing enough clearance for the back end of the pan to duck out from under the valve body since it hangs lower than the pan to trans mount flange and certainly the filter does. I never touched any of the exhaust mount hardware at all, be that the engine manifolds to Y pipe, the bracket on the side of the transmission, or the two bolt flange further back behind the trans/transfer case. I put the truck up on four jack stands as there was no way I was going to struggle with that lack of clearance under the truck. The truck was cold as it had sat over night so all the trans fluid had drained to the pan, so I drained the bit of oil that would come out of the level check plug at the bottom near the front of the pan and put the plug back in to reduce the ensuing mess after that. Then took out all but one bolt front and rear and then pushed up on the pan and took out the remaining two bolts and then let the front of the pan tilt and spill out most of its contents into a drain pan. I then popped the pan gasket off its two locating nubs and kicked it a bit to the left side so it was no longer on the flange of the pan to get all the clearance I could and managed to get the pan slipped out of there by swinging the front of the pan to the right but keeping the rear part of the pan inline if not slightly to the left of its mounting flange area and lifting the front of the pan enough to keep the rear part of the pan low enough that allowed the pan to "JUST" slip out without forcing anything. I installed a new trans filter and seal and as per GM instructions on this site I torqued the two bolts to that 44 inch pound goal ( they take an 8 mm socket ) In reversing the pan procedure after I had cleaned up the pan both inside and out completely ( touching the outside of a dirty pan and dealing with installing a gasket at the same time would be a disaster ). First I slipped the pan into place and yes it took me a while as it won't go unless its slid in just at the right angles, then once the back of the pan was into the area of the flange mount, I went and got the gasket and then threaded that through the front of the pan and feeding it under the filter etc and finally working it onto the flange of the pan and lining up the two locating nubs to drop into the pan. Then lifted the pan up into place and get a couple of bolts started and check and make sure the gasket is where its supposed to be as the bolts were being put in. I never used any power tools as I don't have any of the whimsy little drive guns, I use what looks like a small screw driver handle with shank that has a 1/4 drive on the end of it and added an extension and those bolts use a 10 mm socket as some times power tools can bite a person if used on delicate parts ( torqued to 80 inch pounds ). Also should note as per rules around pulling the add plug out first, yes I cracked that loose with a 8 mm Allen bit socket on a 3/8 slim head ratchet as there isn't a lot of room to work with there either due to the exhaust on the right side of the trans.    I already had delco ULV oil on hand and of course the quart bottle pump wasn't made for those small cap threads so I had to use some other containers that the pump would fit and keep transferring oil over into them so a wasted exercise there but indeed the small pump did work just fine as ULV oil is thin and easy to pump in summer time weather. I put in 9.5 quarts as per prior minimum recommendation and yes that cut it pretty close as once I had the truck ( off the jack stands so its level ) and the trans oil up to 167f , about 6 ounces came out but a level kit or what have you could throw it off just enough that it wouldn't be enough oil so probably that 10 quarts is a good amount to put in so one doesn't have to add more oil as when its hot I sure wouldn't want to be adding oil so would have to let the exhaust cool. All I do for warming up the transmission is sit there with it in park and rev it to about 2500 rpm and it takes close to 20 minutes to get it up to that lower limit of 167f, weird how it will warm up more doing that then by driving it, I am not real keen on power braking the truck to get the temp up there and don't seem to have to either. By the way I only have 9000 miles on the truck so probably not a very good payback on doing it that soon and the magnets had such a minor thin layer of fines on them so that was good to see and the color of the oil was a darker red then new oil but still looked very good as it should and I've not done any towing with it so its been living a pretty easy life so far. The filter is made in such a way that its next to impossible to pull out the filter media but there certainly was some fines showing up there which makes sense give the trans having to break in.    I hadn't really planned on explaining this much of what I had done since there are various instruction videos kicking around or I think so, as the gist of my message as that by fluke or what have you, for some reason my truck has just enough clearance to slip the pan out from the trans. Of course there is no guarantee that other trucks like this in general will also allow the pan to be taken out without messing with the exhaust as I expect its probably a crap shoot if it will or won't, I was just happy to find out that mine would work and avoid all the other struggling and possibly damaging things in the process,
    • Do you fellas think Fog Lamps would  be a good upgrade for our 2024 2500 HD Custom ? As you probably know it did not come with them ,  Would you put in GM Chevy parts ? Do they get wired up to the switch panel ( Upfitter or whatever the correct terminology is ) on the dash ? Thanks
