My buddy's 2018 duramax
He ordered a 2018 duramax just came in to dealer.  No running boards or factory 5th wheel...the dealership told him gm don't do that they make the dealers do that.  That is pretty hard to believe...just wanting to know if this is true.
The running boards that were optioned on my SLT were installed by the dealer as part of the dealer prep. I would think they would get damaged in transit if bolted on the truck.
Mine didn't come with running boards and I'm thankful it didn't. I'm not a fan of the factory style
Mine came from the factory with the 5th wheel prep.. dealer doesn't install that because it's actually part of the trucks frame and has pre cut holes in the box floor with covers lol.  Boards are boards.. pick your poison there.
But to the original post, yes there are a bunch of options that are dealer installed -- the boards is one.
They are listed in the fleet order guide as dealer install.
They can likely all be ordered thru GM accessory as well, so that they can be added on a lot or dealer trade vehicle.
5th wheel/gooseneck is factory.
Running boards are ordered with truck, the go to GM parts Depot and are shipped to dealer when truck ships to dealer, they are dealer installed at time of prep.
Dealer is a idiot as usual, if he ordered the truck I don't understand where the miscommunication is. All the codes and options would have been listed on the order sheet.
He needs to make sure to check all his codes and to double check those items are installed on the vehicle.
Any time I've ordered a truck (w/ the exception of 1 screw up back in the 80s), I've watched the salesman input the codes. W/ the process done online, it's quite easy to follow along. I'm not sure about my '04 but I know w/ my '11 & '17 I basically watched as he worked his way thru the process. Pretty hard to 'miss' checking off an option.
My '15 High Country did not come with 5th wheel but the dealer had to install the running boards, cargo box side step, and the chrome front tow hooks. I bought it before they PDI'd it and had to wait for them to put the running boards and step on. Had to take it back to get the chrome tow hooks because they forgot to put them on.
Sometimes changes get made during the order acceptance process between dealer and gm.  But I agree, the input process is pretty easy and straight forward.
I had a printed copy of the exact order input into the system - the DMax pkg requires running boards (to hide the DEF tank). I also ordered the pet seat cover, the under seat storage bin and the console organizer - they were shipped separate from the truck and arrived at the dealer ahead of it - the dealer installed them  as part of the dealer prep.
Sometimes things do change at the factory - the most recent issue I remember was the sliding rear window that was unavailable for awhile and of course the ever present allocation on the DMax. So perhaps the gooseneck prep was one of those items that was not available during the build - I agree that it is not a dealer added product - although the hitch and tie downs probably are.
Doesn't work that way, if option is not available it delays the order, the order doesn't continue through with missing options.
I always bought off the lot. Any add ons I went to professional outfit where that was their specialty. Usually cheaper too.
R8M is the delete code if you don't want the rectangular steps that are in the Dmax package on a SLT or LTZ
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
