Just traded out of my NNBS Sierra into this 2018 Silverado. Went with 2" level with factory 22s, and 305/45-22 Terra Grappler G2s. Better pictures to come
Looks great... any rubbing?
Only if at a certain angle at full lock. Has 1500 miles now and has rubbed maybe 3 times
Had a 2" MotoFab level installed last week.  Truck sits darn near perfectly level.  Still have stock 20" wheels and tires but that's gonna change this week.  I'm going with Method Mesh 20 x 9 with Falken Wildpeak LT285/55R20 tires.  Can't wait to get 'em on.
I have a quick question. I am tossing around the idea of keeping my stock Silverado z71 rims. Can I use 1” wheel spacers without cutting the bolts?
Installed Bilstein's at the top notch.  Raised the front as advertised, just shy of 2".  Rides fine. Still about a 1" rake from front to back even tho the picture doesn't quite show it.  I'm good with the stance and happy I used the top notch. 2018 Z71 with stamped arms.  Stock size tires for now.  Plan to upsize to 33"
Edited by Donzi4me
Well, if you cut off your wheel studs you have problems. They knock out with a hammer and you can put longer or shorter ones in, don't trim yours as a grinder will heat up the stud making it weaker. You can also buy a 1" spacer that uses your factory studs to mount the spacer, then bolts on the spacer itself to secure the wheel. I don't recommend spacers as they increase leverage against your wheels resulting in premature tire and front end parts wear. They look like these https://www.amazon.ca/Spacers-Suburban-Silverado-Cadillac-Escalade/dp/B0179ZEQSU?SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duc12-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B0179ZEQSU Do not buy those ones, buy a quality part made in NA from a reputable suspension company as you don't want your wheels coming off. I don't like Chinese Sweatshop parts responsible for keeping you alive.
Edited by L86 All Terrain
I'm sure this has been answered in this thread, but I can't seem to find anything. I bought a motofab 2.5" level and plan on keeping the stock wheels for a while. I've seen several different questions on here, but haven't seen anyone mention 265/65/R18 with a 2.5" level. Should I expect rubbing or anything?  I never leveled my previous trucks, so I'm kind of new at this.
Edited by RedSox14
265/65/18 was the stock tire size on my truck. You won't have any rubbing.
    JWeather
    JWeather
  • Who's Online   5 Members, 0 Anonymous, 495 Guests (See full list)
