I absolutely hate the tow mirrors for the look but the function is probably worth it.
I'm thinking full paint match and they would look better
Sent from my SM-N975W using Tapatalk
I get a lot of unsolicited compliments because of the tow mirrors. People say it complete the look of the truck. But, mine is a Trail Boss.
OK....this really sounds totally legit and very worth doing!!!    Now I'm looking into this for mine.   I am a first responder and if I'm at a scene and someone needs something from my truck it's easy to just give them the code.
Can reprogram the code on your own?
Yes you can make your own code.
I'm between thoughts on the mirrors. I like that it makes you look like an hd. But I like how dodge did theirs. Small everyday then up when you need them. I figure wanting the function of the tow mirrors I'm going to lean into the big truck look instead of going street truck style.
Coin op spray off. Needed to be less salty after our first snow. I supplied my own foam [emoji16]
Since I was unhappy with the supplied bed lights and lack of being able to turn it on from the back of the truck, I installed a led strip light kit. Ran power from the charging cable on the 7-pin trailer connector.
6 minutes ago, bonzman17 said:
Another picture
Plan on landing a helicopter in the bed of your truck???    ??
Looks great, there never enough light when you need it.  Good call on the button placement, they should have put one there.
1 minute ago, bonzman17 said:
Never know....
In all seriousness, it does look VERY good.
15 hours ago, toycloser said:
Congrats ! that’s one heck of a Christmas present!
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
