Since I was unhappy with the supplied bed lights and lack of being able to turn it on from the back of the truck, I installed a led strip light kit. Ran power from the charging cable on the 7-pin trailer connector.
Where did you get that switch?
Sent from my SM-G975U1 using Tapatalk
3 hours ago, bonzman17 said:
MICTUNING 2Pcs 60 Inch White LED Cargo Truck Bed Light Strip Lamp Waterproof Lighting Kit with On-Off Switch Fuse 2-Way Splitter Cable for Jeep Pickup RV SUV and More https://www.amazon.com/dp/B01JUE9OLM/ref=cm_sw_r_cp_api_glc_fabc_3.X4FbB58TX16?_encoding=UTF8&psc=1
 It was part of the kit
How did you make the connection to the 7-pin connector for power/ground?
I was looking for a switch for the bed lights on the Ram trucks there's a switch just in by the light to turn them on and off with the truck started or not as pretty awesome.
I was planning on adding extra lights to my truck also underneath the bed rail and wiring them into the factory bed lights but with no switch it's kind of a hassle so I may do the same thing as you but wire them to my upfitter switch kit
Sent from my SM-N975W using Tapatalk
13 hours ago, Thejet07 said:
Which wire was the power?
Going off memory it’s Orange with a red tracer or it maybe red with orange tracer. I do 100% remember that while looking it at from under the truck the wire is at the 11 o’clock position.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,315 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
