5 hours ago, Offroadman00 said:
Sweet UTV!!! How much do one of those go for, ballpark?
Thanks!  This is the new “S” model from Kawasaki.  It runs about $18k   Comes with a 3 year warranty right away. Can add another 3 years also at extra cost.   No one comes close to that. Most have 6 months or 1 year to start with. You can purchase up to 5 year, but it will cost you extra. I did tons of research on these UTVs and this one fit the bill. And every review I’ve read has stated they are very well built and reliable.  That’s what I wanted.
I've done a few things since my last post. Lately though, I added some Husky bins from Home Depot that fit perfectly up against the back of the cab in the bed. They should help hold smaller items from sliding and rolling around as well as holding groceries.
I also Raptor Lined my bed and added MAPS panels from Valhalla Off Road as I slowly start a basic overlanding/Camping setup. I still have more things to add to the panels.
Edited by MikeW81
I've also added Sealight LED headlights and brights, Lasfit reverse, turn, and emergency lights. No need for pics as plenty of guys have done that already.
I also added Husky front and rear mudflaps and rear wheel well liners. I know some on here don't like mudflaps, but I do.
Lastly, I also added The AVS Aeroskin 2 bug deflector.
If you want/need pics of anyhting, just ask, but there should be plenty of pics of all of these already.
Do you have a picture of the Aeroskin 2?
On 5/13/2021 at 4:30 AM, Offroadman00 said:
What will you be using to cut the tracks?
i have the Retrax RX and want to cut them to have access to the side bars for when I decide which ones to go with, just not sure what to use to cut and how to make it look clean and not show the rough cut areas and how to prevent rusting later
Whatever works.  Probably my jigsaw.  Since the rails are made of aluminum I'm then going to a welder to have them weld in new pieces of aluminum to close up the openings I make and reinforce those areas.  Looking into the weatherstripping/rubber foam that's on the under side of the rails and will be adding more where I have all this work done, too.  As for rust prevention, fortunately these are made of aluminum, so not much will be needed to prevent rust, but I'm going to be painting or powder coating to clean up the look.  Haven't decided on that part yet.
As for concerns about smoothing out the rough parts of the cuts, you can use a dremel with the cylinder sand paper at a high speed to smooth the edges.  You'll probably use a few of them, so make sure you have plenty.
Edited by Transient
Had the front windows tinted. I replaced the stock badging with the black badges from GM. For the Z71 badges, I went a bit different route than others. I thought the chrome/black combo matched my LTZ better than the plain black or black & red emblems.
On 5/9/2021 at 2:17 AM, Transient said:
For which parts?
On 5/9/2021 at 9:31 AM, bdallas said:
I would assume he’s wanting the part numbers for the carbon trim pieces you installed.
 Yes, I was wondering what the part numbers were that you ordered to replace the wood look trim in the door panels with carbon fiber. Also, if you have pictures, please share. Thanks.
I posted the part number shortly after the post you quoted, but I'll be kind and post it again.  84458971  This is for crew cabs with center consoles.  If your truck isn't a crew cab, or doesn't have a center console you'll need a different part number.  Best way to sort it out, imo, is go to accessories.chevrolet.com, enter your VIN, and look under Interior.
I've tried posting pics, but apparently there's an issue with this site and at least 1 of the pics.  It would be great if the admin could get this site fixed so I could use tapatalk again.  It makes posting pics much easier.
thanks
A few weeks ago I put on a Fab Fours Matrix bumper.  Last night I finally got around to installing the GM upfitter switches and wired up the 30" led light bar.
Installed a Lomax tonneau cover from Truck Alterations thanks to Luke Kyle there. Install took less than 20 minutes. It’s the matte finish and sits flush.
