2019 RST Z71 in Satin Steel Metallic
6" Rough Country Lift
20x10 Fuel Contras
35x12.5x20 Nitto Ridge Grapplers
  • Like 10
Got my 20 AT4 CarbonPro Duramax in satin steel. Sharp truck and I love the 3.0 so far.
  • Like 10
Here's my brand new 2020 Sierra Elevation X31 with the 3.0 Duramax!  I've been a Ford guy my whole life but after two lemons in a row and absolutely terrible customer service,  I've given up on them and I couldn't be happier with my decision!
  • Like 10
Did you drop the rear or is it just the picture messing with my eyes? I like it.
 Thanks!  No, it's completely stock.  It has the X31 package with Rancho shocks/struts so I don't know if that lifts it any over a non X31.  Also, I just wanna say, the fuel mileage on this truck is insane when you keep it under 65 mph!
Sometimes you can get over the problems with certain vehicles but being treated poorly over and over again when in for service  after spending a lot of coin on these new rigs is just unacceptable.  That’s when it’s time to move on....
Great looking truck by the way ?
This Satin Steel is really classy looking, loving it more and more everyday...?
Make it look like this .
They look good with a 6" lift.
Edited by dieselfan1
In the middle of installing a front Focal Flax front 3 way component setup with one JLTW3 and did a full sound deadening and decoupling treatment with Dynamat extreme and some of that cheap noico stuff for the rear cab since the rear doesnt see as much of the heat.  then later this week Il be doing a full paint correction, polish, and ceramic coating (what I do part time since Im in college). Should only take me 2 days since shes so new but I go panel by panel and utilize a 4 step process and am pretty meticulous about my vehicles. Also Im gonna be adding a ready lift leveling kit to the front, a magna flow exhaust, drop the kooks long tubes in the old girl drop and am contemplating one of those fancy badlands off roading bumpers well see tho gonna have to crank out a few more high end car this month to get the cashflow going for this hobby of mine.
  • Like 4
25 minutes ago, Robotaz said:
You can almost sleep on those side bars.
Lmao yea I was gonna go for the low profile ones but my wife went truck shopping with me (never again) and wouldn't stop complaining about getting her footing (shes not fat I promise just clumsy) so I bought the damn things cant say they haven't grown on me though
    LCH14
    LCH14
  • Who's Online   5 Members, 0 Anonymous, 957 Guests (See full list)
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
    • With this new pan, do you still use the same procedure to check the level? Its a deeper pan and our trucks do not have a fill tube/dipstick. So fill till fluid runs out the check plug?
