51 minutes ago, wendilea said:
Newsflash . Some people actually use a truck for work. Some actually buy a work truck . Now hold on to your chrome bumpers , some have regular cabs because they need an 8 foot bed and prefer the company of their dog ..... twopffenig
Before this truck, I had a regular cab S10 with a bench seat...but the engine blew up, and I miss having my dog up front. Between being nervous about using such a nice truck, and not having my dog up front, it made me have a little regret about buying the truck instead of another basic truck.
18 hours ago, TheTicketTX said:
You keep those pavement queens looking pretty with all that chrome ?
Don’t want to get all that pretty chrome dirty!
Look at this pavement princess doing some off-roading to get to the bike trail head! (Ignore the road 10ft from me ?
Haha, nice looking truck! I have a 2014 GMC Sierra Texas Edition, as well, as my daily driver  w/ plenty of chrome! Just messin’ with y’all!
Edited by TheTicketTX
My 2019 LT with readylift level... Anyone else worried about how close axle boot is to spacer at full droop?
Like it a lot otherwise!
Edited by woodsrider11
typo
2019 AT4 Carbon Pro stock - then stock wheels leveled, then with 18" Method NV's and stock tires!  IMG_8517.thumb.JPG.a2cbf6a3ba0e0913542876db12358da7.JPG1774283387_LeveledTruck.thumb.jpg.b8535f0f8e583d235494bdb8729f1b63.jpg1306991748_Methods1.thumb.JPG.cb55f8749df4625801514b7a8e1b197c.JPG
Edited by Supercup
1 hour ago, Sam Huff said:
@Supercup I thought the CarbonPro AT4's had black carbon fiber looking badges and the black GMC badge in the grill? The wheels look great BTW.
You are right they do for 2020 - but for the 500 they made late in 2019 we did not get black badges or black exhaust tips - I have ordered to put on as I think it looks better!
Maybe I was bored but thought why not. They will come in handy on a dark boat ramp. Plus my kids think I’m awesome now.
0c882c6eda94732da53c96998b8b9c72.plist4360a9429347504f8692819c5b3d28e2.jpgff90357d363a0ce730e289e017832352.jpg
  • Haha 2
26 minutes ago, Ryguy said:
Put in work today, trimmed a few trees on the farm. I like using my truck!
Man that truck looks good!
Nice. How hard was the install. What did you use?
It wasn’t hard to install. I did it myself. Probably 3hrs of total work. I used the Infinite Off-road basic truck kit. 4 pods and 2 -12in strips. I did the 4watt. They have an 8watt option. I didn’t run a wire into the cab for a switch because it comes with a remote and is Bluetooth to the controller. The wheel well liners have a seam In The middle so you can pull down a little and throw the wires thru. Figuring out where to run wires was the hardest part. Trial and error. I would run it then start over because I go to close to a moving part or didn’t have somewhere to zip tie it. I didn’t drill into anything except the wheel well felt. I finished the driver side last night. 850a80314f40b1cd8e8128320b98ec80.jpg
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
