2019 RST Z71 in Satin Steel Metallic
6" Rough Country Lift
20x10 Fuel Contras
35x12.5x20 Nitto Ridge Grapplers
  • Like 10
Got my 20 AT4 CarbonPro Duramax in satin steel. Sharp truck and I love the 3.0 so far.
  • Like 10
Here's my brand new 2020 Sierra Elevation X31 with the 3.0 Duramax!  I've been a Ford guy my whole life but after two lemons in a row and absolutely terrible customer service,  I've given up on them and I couldn't be happier with my decision!
  • Like 10
Did you drop the rear or is it just the picture messing with my eyes? I like it.
 Thanks!  No, it's completely stock.  It has the X31 package with Rancho shocks/struts so I don't know if that lifts it any over a non X31.  Also, I just wanna say, the fuel mileage on this truck is insane when you keep it under 65 mph!
  • Thanks 1
Sometimes you can get over the problems with certain vehicles but being treated poorly over and over again when in for service  after spending a lot of coin on these new rigs is just unacceptable.  That’s when it’s time to move on....
Great looking truck by the way ?
This Satin Steel is really classy looking, loving it more and more everyday...?
Make it look like this .
They look good with a 6" lift.
Edited by dieselfan1
In the middle of installing a front Focal Flax front 3 way component setup with one JLTW3 and did a full sound deadening and decoupling treatment with Dynamat extreme and some of that cheap noico stuff for the rear cab since the rear doesnt see as much of the heat.  then later this week Il be doing a full paint correction, polish, and ceramic coating (what I do part time since Im in college). Should only take me 2 days since shes so new but I go panel by panel and utilize a 4 step process and am pretty meticulous about my vehicles. Also Im gonna be adding a ready lift leveling kit to the front, a magna flow exhaust, drop the kooks long tubes in the old girl drop and am contemplating one of those fancy badlands off roading bumpers well see tho gonna have to crank out a few more high end car this month to get the cashflow going for this hobby of mine.
  • Like 4
25 minutes ago, Robotaz said:
You can almost sleep on those side bars.
Lmao yea I was gonna go for the low profile ones but my wife went truck shopping with me (never again) and wouldn't stop complaining about getting her footing (shes not fat I promise just clumsy) so I bought the damn things cant say they haven't grown on me though
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
