Traded in my 17 Midnight edition the loud tires drove me nuts and picked up this 19 SIlverado RST 5.3, i've only had it a few days but i like it!
Edited by Thebove
  • Like 3
On ‎8‎/‎4‎/‎2019 at 9:27 PM, Kdluke said:
Fuel Assault Rims 20X10 -18 on BFG KO2 305/55/20
Congrats and i like it but you know they make tires that are quieter that you could have replaced with out buying a new truck??
I’m not one to speak. I buy at least 1 vehicle a year.
Update:
Ready Lift 2" SST Lift Kit for Trail Boss...Very satisfied so far. No  more rub!
Edited by Kdluke
Added pic
  • Like 7
Don't know what's more expensive the truck or all the extras we all install
Tell me about it.... If my wife actually knew the exact amount she would kill me.  Hell, I'm scared to look at the actual amount.
  • Thanks 1
On 10/22/2019 at 7:17 PM, Chance1025 said:
Little update on my “non-blacked out Trail Boss”. Grabbed an overstock bumper, a take off grille, and sold my trail boss 18’s for High Country 20’s. TB suspension with a 1.5” leveling kit. 285/65r20 BFG’s. I love this truck!
I have a new 2020 HC Crew 4X4 and I'm having the TB lift installed along with a 1" level in the front.  I want to use 285 65R20 tires as well.
What did you have to do to get your tires to fit without rubbing?  Have you had it on rough terrain?  have you had any issues at all?
I love the look you achieved!
12 hours ago, cameronalbrecht said:
Did you have to do any trimming to get those tires to fit?
I removed the OEM Mud Flap and plastic bracket added SCA Flares and still had a rub at full lock. Then added the Ready Lift Plus 2" SST...no more rub.
Looking good brother..?. Luv the wheel flares ,  really pops with the Satin Steel Metallic..
Edited by Joe98
The Trail Boss is lifted via a longer strut assembly in the front so you could put a leveling spacer if you wanted but they are not out yet.  From what I heard when talking to several lift companies, they will be releasing lift kits around SEMA for the Silverado/Sierra, but the Trail Boss/AT4 will only get limited lift kit options with some companies telling me that they will not make them for that specific model.  I myself am waiting for them to release a 2 inch lift all around for the Trail Boss so I can have a total of 4 inches of lift and squeeze in 35s.  I have 33.5 x 12.50 x 20 tires on my truck right now with a 0 mm offset 20 x 9 rim and they only very slightly rub at 100% full lock, otherwise there is no rubbing.
Sounds like the same shit they did with ZR2s...limited options
Thank you Joe!
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
