On 12/22/2019 at 8:58 PM, James S said:
2019 Silverado LTZ with Factory 2 inch Trailboss kit... additionally, I leveled it with a 1.75 inch kit from Readylift. Stock number on www.readylift.com is 66-3921
Your truck looks PERFECT!!!   Can you tell me about this TB lift you used? Is that a dealership item? What was the cost if you don'r mind saying?    Thanks    I have the Northsky Blue RST and want it set up like yours
What  MPG are you getting with the 2" factory lift with the Readylift leveling kit?
56 minutes ago, STX30MAC said:
Truck looks great. Have any pics of the entire truck? What are the specs on the lift? Reminds me of how 4wd trucks used to look in the 80s with solid axles. I like it.
6in BDS
35x12.50 Nitto RGs
Stock 20s no spacers
RC Vertex coil overs
Fox rear shocks
7583050ec5208e210d68bb3458f035b8.plist28764cb1830d6b24ce79f4d6631cfd03.jpg8a2de359e2d68d2f926b9099b1110856.jpg
On 1/10/2020 at 12:32 AM, Phi Shoe said:
I traded in my 2016 Sierra for this 2020 RST with the new inline 6 diesel. First 2020 in the state of Mississippi. I put some black wheel skins on it until I could decide what wheel and tire setup I want to go with. Just taking my time with it.
Where did you get the black wheel skins? And how much if you dont mind me asking
15 minutes ago, Method2Madness said:
Took a few pics today after installing my AVS hood protector.
Nice looking truck
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
