On 1/5/2020 at 4:57 PM, michael betz said:
Your truck looks awesome! Did you get the headlights tinted at a tint shop or order the tints from Rvinyls that I see online?  Or did you get something else, let me know!
17 minutes ago, Robotaz said:
My CTB lights are so crappy that I’d be very afraid of tinting them. Maybe with some LED upgrades.
Lol, I have an LT TB with the LED lights. My truck is all black and I love the black out look. I wanna do the tail lights too and just leave the reverse light cut out. What I really want are those cages that go around the tail light (off road protectors or whatever you want to call it that I always see on jeeps) but they don’t make those for the 2019s that I’m aware of.
Bad news. I have the led upgrade had to take them off. Was like having no headlights
On 1/6/2020 at 9:37 AM, bell1658 said:
Thanks!! Yup tires are Nitto Ridge Grapplers, 285/45/22
How is the ride on those? And noise? How bad do they hum?
The ride is fine with no hum/noise thats out of the ordinary...that I can tell.  My last car was a sports sedan so I don't have recent experience driving a full size truck to compare it to.
On 1/5/2020 at 11:10 PM, bell1658 said:
Few pics of my black RST20200105_141458.thumb.jpg.f4a6b3729aa09d45e91f38da2ced3dee.jpg20200105_141352.thumb.jpg.2da65843634434cb6079fa1c4a35a704.jpg20200105_141340.thumb.jpg.4258d44e26f10f8495f4656ddcc7e014.jpg20200105_141310.thumb.jpg.b464eb44d2ddf5f2ee971dafa47f9ab6.jpg
That is one SICK looking ride!!!!!!
I traded in my 2016 Sierra for this 2020 RST with the new inline 6 diesel. First 2020 in the state of Mississippi. I put some black wheel skins on it until I could decide what wheel and tire setup I want to go with. Just taking my time with it.
Edited by Phi Shoe
  • Like 3
23 hours ago, grapedrinkesha said:
Upgraded from a 2016 Silverado to this 2020 GMC Sierra and wow am I in love with this thing!
WOW that is awesome!
Nice.
I’m really curious if this diesel will prove to be anything close to as reliable as the Cummins. I hope so because one will be in my future if it is. I love all straight six engines.
Some updated photos of my 2019 RST. 3 inch MotoFab kit on 22x12 Arkon Lincoln's on 33" Atturo Trailblade MTs. Removed the front and rear mudflaps and put color matched fender plugs and removed the front lower valance.6c9a1f748f5beddac2d0f4a6a9bc1699.jpg8451fda2ebbc0ede4234f09bd41628fc.jpg1a86e1dcefd4c032845f9913324012a4.jpg
Sent from my SM-N975U using Tapatalk
  • Like 7
How was the fit on those wheel skins? I have those same wheels on my 2019 RST and was debating on doing this.
The fit is perfect. I can’t imagine there being an issue with them popping off. It’s a cheap alternative that works.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
