On 1/9/2020 at 4:05 PM, grapedrinkesha said:
Upgraded from a 2016 Silverado to this 2020 GMC Sierra and wow am I in love with this thing!
You should be in love.....that’s a gorgeous truck you got there my friend ?
18 hours ago, Cohocarl said:
Put on close to 900 miles yesterday traveling to and from Houghton MI.
That's salt from the roads (on the sides, not tailgate) in case you've never spent a winter up North.  ?
I know all about your pain sir;  being from the Toronto,Ontario Canada area.  They luv there salt up here too...and when we’re not salting we’re brining !  Lol...just can’t get enough of it.  Funny thing is everyone wonders why all the infrastructure is failing :  asphalt, concrete, potholes, culverts, ditch inlets....it’s a miracle all the animals in the woods aren’t coming out of the forest due to salt poisoning.  If people up here knew how to drive in the winter we wouldn’t have to go overkill for a half inch dusting of snow ?
Since you mentioned it, I wanted to let you know that salt wrecks the pH of the entire environment, mainly the water. It’s a stupid plague and a symbol of man’s idiocy that an alternative is not feverishly pursued.
My hometown in western Kentucky uses something based on beets, of all things, and does not use salt.
It’s a big problem though. Huge.
Hi everyone! Finally registered after lurking for awhile. Upgraded from a 2018 Silverado LT to this great truck so far 2020 GMC Sierra SLT 4x4 X31 on 12/31/19. Loving the 10 speed on this truck as it shifts so smoothly. in just two weeks I have done a few mods including getting the GM 2 inch lift kit installed yesterday.
A little dirty on a couple of pics since weather has been wet lately. First pic is when we picked it up. Second is when I dropped it off for lift kit install and rest after kit was installed.
Very satisfied on the way it turned out! Highly recommended!
  • Like 4
New to the forums figures I would chronicle my Chevy build here. Came over from a 2013 Tacoma. I’ve done a few mods, much more planned on the way so I’ll crate a new thread to track the build in case anyone is interested.
  • Like 3
Straight piped
Zone 1.75'' Leveling Kit with 295/70 18 Nitto Trail Grapplers (Had to remove mudflap)
Driveway is a bit uneven but looks much better with bigger tires and a level
Edited by Chandler Wiegand
typo
  • Like 4
2 hours ago, Ritchie Brown said:
Nice, looks good. Probably my fav RST color. What kind of leveling kit do you have?
Had to update my truck with fun car picture. Sold my Boss 302 and found this SS.
Edited by smrr1
  • Like 4
Thanks. Trying to decide on tire size. It’s a Readylift 2 inch.
On 1/9/2020 at 8:29 AM, vonrokker said:
That is one SICK looking ride!!!!!!
Thanks bro!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
