On 8/6/2019 at 8:26 PM, Stormtrouper said:
Here you go, 1.5" level, 3 inch rear blocks, 2 inch spacers, flares, tint, bedliner, wheel wells, vent visors, toolbox. Need black tailgate letters and I'm done. Decided against white bumper for now, may debage and paint it all white later???
Very nice, are the 2 inch spacers on the wheel/rims required?  Can you share the brand or part numbers for the 3" rear block and 1.5" front level kit?  Need this!
https://m.facebook.com/pages/Wheel-Outfitters/100228147982993
Link for spacers?
Motofab 1.5 trail boss level.
Standard 3" inch rear block and longer u bolts??? I provided 1.25" oem blocks from my '15 but installer said he had trouble stacking them. So he ordered me 3" cast steel blocks from somewhere? They look stock only larger.
2019 Silverado LTZ with Factory 2 inch Trailboss kit... additionally, I leveled it with a 1.75 inch kit from Readylift. Stock number on www.readylift.com is 66-3921
  • Like 7
Just picked this up on Monday. 2019 AT4 with factory installed cold air intake and cat-back exhaust (this combo adds to the 420/460 and makes them 435/469). It's the most beautiful sound I've heard on a truck in recent years! It's the reason I bought this particular truck and not others that were closer to me.
Finally pulled the trigger, even though I always said it was too much to pay for a truck.
Edited by Villain
  • Like 10
On 8/18/2019 at 5:50 PM, Steven Rhodes said:
Just picked it up. Ordered in June 6th, Build date was 7/22/19. Delivered to dealer and Picked up on 8/16/19.
2019 Silverado Trail Boss LT.
Satin Steel Metallic
Black Leather Package
Power Sunroof
Trailer Brake Controller, integrated
Engine Block Heater
Convenience Package with Bucket Seats
Convenience Package II
Safety Package
LPO Off-Road assist steps
Bed Protection Package
Advanced Trailering Package
Is your block heater integrated into the bumper or by the tow hooks? I am trying to understand how the 3.0 Durmax will be...
Absolutely love your setup man. Was thinking about adding the TB lift to an LTZ. Ended up just getting a Trailboss instead, but your making me jealous! What size tire are you running?
Also, you are the first that I’ve seen on here with the Readylift kit. It says 1.75”. Did you happen to measure? I added a 1.5” motofab to mine (should be exact same setup, suspension wise), and I am not completely level. Another 1/4” sounds dumb. But do you have any side profile pics? Do you feel like it’s perfectly level?
Does it look level? Looks nose high by a descent amount. From the sounds of it he stacked 2 kits together (2 factory and 1.75 readylift) which is generally a big no no, that front end isn't going to love him long time if that is the case... Much preferred how he had it originally with just the TB kit.
Tyler
  • Like 3
Toyo 35x12.5x22 Open Country M/T's
2" Level Kit
Blacked out 5% tint all around
Powder coated stock 22" wheels
Blacked out GMC front and back.
More mods coming...
Edited by rosepaule
  • Like 10
Thank you! I haven't measured but it looks to me like the front is just a hair taller but hopefully it will settle over time. If it doesn't, i might take out the bottom strut spacer and see. I am running a 275/65/20 Nitto Trailgrappler. Can you send me a picture of your truck? Do you have on looking straight on to the front?
Pictures are a little deceiving man. To my eye, I feel like it’s still a hair low in the front. I still measure 1/2” low.
Yeah man that looks good! You are right... it does look level. I will measure mine when i get a chance and let you know what it measures. You measuring from the ground to top of wheel well?
Edited by Aycock1987
Tyler
The 2 inch GM kit is a taller strut... no spacers. That is where they get the 2 inches. This isn't stacking spacers on spacers. This kit from Readylift was specifically designed for the Trailboss and AT4
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
