4 hours ago, Collyext said:
Got mine almost 2 weeks ago  Pearl Tricoat 5.3 crew cab. This truck is so much better than my 2017 I had. BA72634C-7E5A-4BE4-946F-8BCC9BAC67BE.thumb.jpeg.87ee1201eee58123f5fd5067c951d0c9.jpeg
This look sick. I really like the color matched grill and bumper
I really regret not going white or possibly pearl. Beauty truck
How did you do the usb 3.0 ports?
Yep
Grabbed a couple of these ports on Amazon for 13 bucks. Pulled the dash apart and tapped into the existing 12V port to give me power to this.
Now I have 4 QC 3.0 ports to charge everything at once.
LT Trail Boss Upgrades
Tint Complete Today. Looks so much better !!!!
Loving it so much I have already started upgrades.
Mods Complete/In Progress
LED Tailgate Bar - Done
Quick Charge 3.0 Ports Front and Rear - Done
Tinted Windows - Done
Bed Mat - Ordered
Backflip Tonneau cover - Ordered
22 Inch Black Wheels - Ordered
Nitto Tires - Ordered
Floor Accent Lighting - Ordered
LED Bed Light Expansion - Ordered
  • Like 5
New to the forum. Lurked for a while, long time Chevy fan, love the community and all the great info here.
Chevy used a picture of my truck in their Memorial Day social media campaign. Kinda cool to have them contact me for that and to see it in my feed as I randomly scroll through one day.
This is my current ride. 2019 Silverado 1500 LTZ crew 6.2L and my fifth Silverado over all.
My previous models were:
2009 LT Z71
2012 LTZ 6.2
2014 LTZ Z71
2017 LTZ Z71 Midnight Edition
and a 2000 S10 Xtreme back in the day.
My wife is on her third Tahoe, currently driving a 2017 LT Z71.
  • Like 7
2009 LT Z71
2012 LTZ 6.2
2014 LTZ Z71
How do you like the GM power steps? Do you have the power step switch inside too? I just ordered a 2020 LTZ, and I kinda regret not ordering the power steps. I had planned on getting the AMP steps, but I kinda like the GM steps...a little late now I guess  ?
I like them so far. Occasionally, they won’t retract like they are supposed to and will remain in the extended position until I start to drive away. Other than that, I haven’t had any issues with them. I like the feature of being able to extend them to the rear to reach into the forward portion of the bed. Being a shorter guy, that helps.
Having never tried the AMP version, I can’t really compare the two.
Keep us posted on the progress of your custom order. I’ve always been curious about the process of doing that and getting everything exactly as you want it.
Good looking truck.
My last 3 trucks have all been whatever white tricoat GM had at the time - 2012 LTZ 5.3 2WD CC, 2016 SLT 5.3 4WD CC & 2019 Denali 6.2 4WD CC. Loved every one of them - 2016 was my least favorite due to the 8 speed transmission clunkiness.
On 1/7/2019 at 2:58 PM, mbr2ooo said:
2019 Silverado LTZ with GM 22" Denali wheels.
Nice, simple mod. Have those on my Denali. Pretty nice for factory wheels & polished wheels seem so much easier to maintain.
Thanks... I like these wheels better than the High Country 22s, plus it's nice to have something none of the other Silverados out there have.
Picked her up a week ago. So far I’ve tint matched the front windows and had a rhino liner sprayed. Also put on tri fold tonneau cover and the GM “work truck” steps. The steps are half the price of most steps GM offers but I prefer the look to all the others. Next I plan to add a more aggressive tire, level it off or lift it just slightly, cover up as much chrome as possible and add a subwoofer.
  • Like 4
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
