I read that you opened the dash to install the 3usb charging system.  How difficult was that?  You must have some expertise with these type of installs as tapping into the existing systems, scare me a bit, lol.
Nope.
I do this once every 4 years with a new truck.  It literally takes 10 minutes to take the whole thing apart and have it laid out to work on.
7 8mm screws and a whole lot of body clips to pop loose.  Way too many in my opinion.
The toughest part is getting that bottom trim piece off.  For a piece of plastic that small it had 5 body clips on it.  It doesn't need that many to hold it in.  I removed the center body clip when I reinstalled it to make it easier to remove later on.
  • Thanks 1
Grabbed a 19 Trail Boss Custom about a week ago. Wanted a strong base for an Overland build out. Love it so far. But a little hard to find Overland Parts. file1-16.thumb.jpeg.5fb9fab20cd145427964fb294896f740.jpegfile-25.thumb.jpeg.9a1174a7d27f18fbe10baf1fcf366f45.jpeg
  • Like 7
1 hour ago, Sir Squallywally said:
2019 Silverado LT Z71   with ARE Z Series topper
Looks great ?.  First I’ve seen of the new generation trucks with cap.
Tonneau and Bed Rug Done!!!
My wheels and tires came in today as well. Can't wait to get those new shoes on the beast!!
Mods Complete/In Progress
LED Tailgate Bar - Done
Quick Charge 3.0 Ports Front and Rear - Done
Tinted Windows - Done
Bed Mat - Done
Backflip Tonneau cover - Done
22 Inch Black Wheels - Arrived
Nitto Tires - Mounted on Wheels
Floor Accent Lighting - Installation Tomorrow
LED Bed Light Expansion - Ordered
Well...traded the '14 in, which was a GREAT truck.  I never experienced the new model year issues that others had with that body style...
But there are things the T1 body has that you cannot mod into those trucks (interior cab size, AC vents, etc)
So, here you go:
2019 RST CC Std bed Z71 with convenience pkg II.  Good mix of options.
  • Like 3
So, here you go:
Standard bed FTMFW. Love it bro. Love painted bumpers.  Congrats.
Thanks, I appreciate it.  She's a big girl...
Already have tonneau cover and steps on order.
Need to update my avitar...
Edited by Vicarod
added info
On 9/25/2018 at 1:36 PM, z1boss said:
Picked up my special ordered 2019 Trail Boss about 2 weeks ago.  Loving it so far.  Lots of mods already.
Hey z1boss,
Just a heads up I've got a red trail boss lt as well and you can get the "Silverado" and "LT" nameplates in black too from the chevy accessory website.  Check it out.
27 minutes ago, eapatzer said:
Hey z1boss,
Thanks for letting me know.  I like the way it looks on ur truck!
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 686 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
