Just bought my 2019 GMC Sierra SLE Monday! I’ve always wanted a full size truck and when I went looking I couldn’t pass up this beautiful truck!  I bought a 2016 Tacoma TRD sport before because I wanted truck with good gas mileage, but after I got cancer last year and recovered(not trying to post a sob story) I decided that I wanted to live life to the fullest and by a full size truck.  I can’t wait to mod this truck and give it a even better look!  Look forward to seeing everyone’s awesome trucks!
  • Like 12
Welcome Aboard, Nice truck and congratulations on recovering from Cancer!! Live life to it's fullest!
  • Thanks 1
Congrats on the new truck !  Glad to hear your health is well.   We never really know what curve life will throw at us, so yes enjoy it to its fullest.
  • Thanks 1
New Trail Boss LT here!
Loving it so much I have already started upgrades.
Mods Complete/In Progress
LED Tailgate Bar - Done
Quick Charge 3.0 Ports Front and Rear - Done
Tinted Windows - Scheduled
Bed Mat - Ordered
Backflip Tonneau cover - Ordered
22 Inch Black Wheels - Ordered
Nitto Tires - Ordered
Floor Accent Lighting - Ordered
LED Bed Light Expansion - Ordered
Rough Country Side Steps - Ordered
Hope it all comes together before the 20th. 92ad69665b640fe8f1ef55fce4219a90.jpg
  • Like 7
Got my 2019 LT and had to get more clearance. 3.5" Fabtech with new Dirt Logic Coil Overs, added 1" lift with 1/2" spacers between Coil Over and lower control arm. I measure 4" lift.
Dick Cepek 33x11.5x18. Wheels are XD132 RG2, 18x9
Running boards are Steelcraft STX300. They tuck up nice and direct bolt to factory nuts. One clip used went into a factory hole, great setup.
Edited by TedS
add details
Those wheels looks sharp.
Toyota trucks are not known for good fuel economy.  Never have been I don't think.  Reliable, you bet.  congrats on the Sierra!  Congrats on recovering from Cancer as well!
  • Thanks 1
Bed Mat - Ordered
can you expand on the bed lighting? any info/pics or products to show what you mean
Looks to be fairly high in the front, it is level or higher? May be just the picture/angle.
Bed Mat - Ordered
Bed Mat - Ordered
How did you do the usb 3.0 ports?
Bed Mat - Ordered
Great looking rig.  Looks like the little guy loves it too !!!  ?
What running boards are those?
Tyler
The truck sets level, I replaced the Fabtech 1.5" Block with a 2.5" Block to make it level, I was going to go with a 3" block but the U-bolts from Fabtech were only long enough to go to the 2.5" block for now . I'm going to have the rear leafs re-arched or add-a-leaf. If I add-a-leaf I'll go back the the 1.5" block and gain it that way, just another $300 to $400 I  don't want to spend yet.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
