3 hours ago, turkeeslapper said:
More pics
Looks sharp.  I really like the plasti dipping the Chevrolet .  One of favs so far on here.  Curious how much times it take to do the Chevrolet letters , I’ve not ever seen that done in person .
Thanks wasn’t bad at all. Left the grill on used tape newspaper and drop cloths to cover the engine and area I didn’t want overspray. With the taping 6 coats and peel took about 2 hours to complete. Gonna do the tailgate Chevrolet in black next.
For the tailgate, you can order vinyls or get it done somewhere for ~ $40-50. It will last longer, and some out better for that application.
I would be concerned about longevity of plastidip on those areas.
Yea I found them Amazon pretty cheap, will probably go the vinyl route.  Not sure how well the plastidip would hold up there.  Not to mention the application my be tougher and call for much more prep.
Look's Good, So did you tape around each Letter ??
No taped approximately 1" in around the letters right where the grill curves.  Then when it dried I peeled away the overspray and it separates right at the letters.  So easy!
Definitely a lot of work to do the tailgate letters, you're right. Post it up when you get it done, either way.
Thank You for the info
will do, will prbably go the vinyl route, just havent played with vinyl in the past.  Might have a local shop do it for me.  Tonight the running boards go on!
On 9/6/2019 at 4:17 PM, Smoothbassman said:
LT Trail Boss Upgrades
Tint Complete Today. Looks so much better !!!!
Loving it so much I have already started upgrades.
Mods Complete/In Progress
LED Tailgate Bar - Done
Quick Charge 3.0 Ports Front and Rear - Done
Tinted Windows - Done
Bed Mat - Ordered
Backflip Tonneau cover - Ordered
22 Inch Black Wheels - Ordered
Nitto Tires - Ordered
Floor Accent Lighting - Ordered
LED Bed Light Expansion - Ordered
Can you talk a bit about what you are doing here with the items below?
Links would be great if you have the time.  Thanks much.
Not mine, but I finally get a nice loaner while my ‘19 is being wrenched on again. Really like the Quicksilver Metallic. Super sharp on this SLT. ??
  • Like 4
Don’t understand why that color isn’t offered on the higher trim levels. I’m quite happy with my White Frost but the silver comes in a close 2nd for me.
Edited by Wheelguy
I scooped an OPT 7 Floor Accent Lighting Kit. Installing that this weekend once I find the right dome light wire to tap into.
OPT 7 Kit
https://www.amazon.com/dp/B00OU5LOT2/ref=cm_sw_r_cp_apa_i_mbYDDbC55798Y
As for the LED Bed lighting expansion I picked up a roll of LED lights. I'll be tapping into the existing LED light in the back of the truck and running some LEDs under the bed rail of both sides of the truck all the way to the front. That way I can see everything in there when my Tonneau cover is installed.
The way they designed this truck over the last generation will require me to drill 2 small holes to fish the wires thru. Since these holes will be under the bed rail, you won't see it when it's done.
LED Roll
https://www.amazon.com/dp/B01339G2F6/ref=cm_sw_r_cp_apa_i_ydYDDbK5EGMGZ
I almost forgot about the last addition.
Edited by Smoothbassman
Links
OPT 7 Kit
LED Roll
Awesome, thanks for the information.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
