On 8/9/2019 at 1:28 PM, Tx_Bowtie said:
Just finished up the 4" SST ready lift.  Now time for new shoes!
I got my tires installed yesterday.  Ridge Grapplers 35 x 11.5 R20
  • Like 9
Nice amp steps. How you like them? I’ve got a summit white LTZ on order, and I’m thinking about getting some. But I’m not 100% sure I’ll like the black step on the white LTZ. I’m curious if they will stand out too much...they look great on your truck though
I love more everyday. I think they would look fine on a white truck. Read the reviews on the Amp Power Steps on Anything Auto and similar sites.
One month update.
Added:
Rough Country LED grill lights
Rough Country fender flares
Windows tinted darker
Westin custom fit rubber bed mat
Replaced 32" old school radio antenna with 14" one
Where did you get the antenna?
Looks great!
1 hour ago, Chriaaas said:
Finally here.  My 2020 AT4 Carbonpro Edition, isn't she beautiful.
More pics please. Looking great
any better details shots of that front end? specifically the grille area, quite unique.
x2 !!!
x2 !!!
That's just how the 2020 AT4 is. They all get the darker grill. Also the exhaust is dark now too.
Looks awesome!  Did they update the wheels ?  Kinda hard to tell from pic.  22’s   Vs 20’s. ?  Either way truck looks great ?
33 minutes ago, Jricharc said:
Seems like an odd wheel choice for an off-road oriented model IMO.
It's not the wheel choice but the highway tread tires.
It is a 22, it's the wheel choice... A 22 is rubbish off road, no rim protection, no added traction or airing down benefits, no improving the ride just a nice high probability of wheel damage at the first rock the size of a softball. Then you have the on road penalties of rougher ride, more expensive tire, lower mpg and slower acceleration/longer braking with the added weight combined with the higher cost. They really should limit wheel size in off road oriented models to 18" or the smallest that will fit over the brakes.
Even in regular street vehicles, we are starting to shop for a new Denali or Escalade and you are hard pressed to find one without a 22 on there; we definitely don't want those trade offs.
Tyler
Tyler
Why does the truck have 22's on it?  Did you put them or dealer added?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
