6 hours ago, Joe98 said:
Gosh...sure she can handle it ?  Maybe should’ve got a 2500 HD...lol.   Just kidding...?. Truck looks great ?.   Really liking that color,  satin steel metallic?
Yup, satin steel, just need to level it and add some different wheels and tires now
Crazy story. 2nd 2019 Silverado in 30 days. This one keeping for a while. Northsky Blue on Nitto Tires. 172122ade0abc00a4c86fc2fdc4ec753.jpg
Sent from my SM-N960U1 using Tapatalk
tell more !!!!!!!!
Teasing us with a crazy story! We're waiting........
On 9/26/2019 at 9:06 PM, Wisco68 said:
Great reason to update my profile. '20 AT4 5.3L
Nice! 10 speed?
Edited by Cpl_Punishment
On 9/26/2019 at 8:42 PM, jamin87ss said:
Not official yet, but stoked to join u guys tomorrow, 20 AT4 6.2 better pics to follow
Frustrated as heck, exhaust and running boards didnt come in picking up on monday hooefully,,,,, wonder if i can get anything outta them for this bs
2019 AT4 6.2 on 20” BFG KO2s
Black Rhino Kelso wheels 20x9 +12
Stock sus? Looking good. Any side shots ?
Edited by f8l vnm
This was a parking lot for a festival when we parked. Came back to no other cars
Ryan B.
If they’re GM parts they ordered don’t hold your breath, GM is on strike, no parts are shipping .
1.5” motofab level.
Edited by Mgmack
Add information
Ryan B.
Always nice to come back to an empty lot, and no door dings or dents ?
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
