On 10/28/2020 at 4:16 AM, GMC207 said:
Ahhh only on Chevys?
you know whats funny is on my 2020 LT 2500 if i use the fob to try nd close it it doesnt close but you can hear a click inside the tailgate......like it wants too but its just disabled or something......on 2021 LT has this feature now i wonder if it can be added to 2020.......sure seems like the feature is already in there just needs to be engaged.....but maybe not.....its only $180 from chevy as an option so that means its a $20 part, lol
The click is the unlock mechanism. The motor that lifts it isn't there.
Sent from my SM-T510 using Tapatalk
easy to do or PITA?
There's nothing there for self closing. The click is the release operating. Only for opening.
Sent from my SM-A505U using Tapatalk
1 hour ago, Chevyguy273 said:
I’ve also just discovered after 6 months of ownership that the interior lights especially the front are useless. Who needs lights aimed at their crotch??
I noticed that too.  They are literally aimed at the doors with no usable light to the center.  I added this and replaced the bulb with a bright LED.
Nice, also like that sunglasses clip holder. How can I get these?
Ever received road head? Apparently GM thinks the girl needs help since people who drive trucks have tiny Ds.
Don't respond to that. I'm probably going to get into trouble with the moderators for posting this.
Seriously though, I've found it useful when trying to read a paper or something else that doesn't have a light up screen. I mean, who needs a light in their face? GM did use the dimmest 5000 Kelvin rated led lamp they could find for that location, though.
  • Haha 1
Love these sunglass holders!   Best ones I've found by far.   I got the double so I take my glasses off, stow them and pull my sunglasses off.
Single:
https://www.amazon.com/dp/B01BGZZ0DY/ref=cm_sw_r_cp_apa_fabc_pJSaGb88AXGT9?_encoding=UTF8&psc=1
Double:
https://www.amazon.com/dp/B00YVQD4A2/ref=cm_sw_r_cp_apa_fabc_gLSaGbVBNNXKX?_encoding=UTF8&psc=1
Yes I have. My college girlfriend many years ago on a road trip driving back from nyc to Maine somewhere on I-84 outside of Hartford, Connecticut at around 1am with her father passed out snoring in the backseat.
  • Haha 2
Um, I did say, "Don't respond to that". I think I can hear the ban hammer coming already.
  • Haha 3
Are the bulbs replaceable? In my 03 Duramax I got much brighter LEDs to replace the incandescent bulbs. It made a huge difference. I then got the same type that fit the mirror in my C6 Vette. It really sucks because being a convertible it only has the mirror lights. No place for a center light in a fabric top. That made a huge difference too but it still sucks. The one in the center of the roof in the 2020 puts out about the same light as a birthday candle behind a coke bottle. That's the one I would upgrade. The front ones would be a problem if you need a map light while driving. They would reflect off the windshield. They can't even be aimed. On the old truck the mirror lights and center light come on together so I upgraded them. The map lights are separate and can be aimed. That made more sense. I don't like that the map lights are part of the courtesy lights. Even on big trucks they are separate. Most have 2 on each side. One clear and one red to prevent reflection. Normally in one fixture on either side of the courtesy light. The courtesy light operates the way our map lights do when you push the lense. But GM went cheap on these trucks and made them dual purpose.
Single:
Double:
Any info on your map light ??
Here's the thread:
Light:
https://www.amazon.com/dp/B0000AYAEO/ref=cm_sw_r_cp_apa_fabc_M1ZaGbGVPEGEJ?_encoding=UTF8&psc=1
Bulb:
https://www.amazon.com/dp/B07H2CFSY3/ref=cm_sw_r_cp_apa_fabc_80ZaGb021384G?_encoding=UTF8&psc=1
I wired it to the unused harness attached to the headliner.
The bulb upgrade is very bright!!!
Edited by fsuboy75
If you unclip the sun visor, as if you were going to swing it to the side window, you can then pull it off the hinge side covering that little spot between the visor and rear view mirror.
It will block the use of the mirror, but I would rather see in what is in front of me than what's behind.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
