2018 5.3L, Which oil/filter do you use?
Was going to change the oil in my truck this weekend & wondering what oil you all are using.  I normally use Mobil 1 in my other vehicles, was going to get it, but saw Valvoline synthetic that says it is formulated for 2012+ engines.  Mobil 1 doesn't say that, but thinking its probably formulated for it.  Both were 0W-20.
Next question, what filter?  I normally use Fram or AC-Delco in my other vehicles.
  • Replies 58
Go for Amsoil. Use their filter too. Best stuff there.
Sent from my SM-G960U using Tapatalk
Same as these guys.  AMSOIL oil and filter.
I actually went with AMSOIL Signature Series 5W-30 instead of the 20 weight.  I have almost 10 more psi at idle when hot, and no loss of MPG.  Is it necessary, no.  But it puts my mind at ease, especially when towing and working the engine harder.
Royal Purple Oil is the best. Dyno proven on my engine right in front of me. 2nd I would say AMSOIL but only because I have heard good things . Different weight oils depend on time of year. Race cars are different.
Oil filter is a different story As I currently am having issues with that. Fitment to the sub frame limits my options.
I also am testing a additive that is allowing me to keep the super low weight oil but resolve the consumption and psi issues. So far it is good but not many miles on the oil yet. New turbo just installed yesterday.
GM Dexos w/Delco filter, at the dealer. Every 6K... I get free oil changes and tire rotations for as long as I own it providing that I have all scheduled maintenance performed there. Just had my 5th oil change. 2 came with the truck, the next 3 were on the dealer.
So far so good.
So far so good.
The latest gm bulletin said heavy oil consumption every 2k. So by 6k you "could" be low 4qt.
Also I see many people are running different weights.
Sent from my SM-N950U using Tapatalk
I check it regularly. By regularly, I mean every 3rd or 4th fill up... I haven't noted any significant oil consumption. Truck is a completely stock 2017, 5.3. 25,000 miles.
So far so good.
Free oil changes as long as you own the vehicle is a sweet deal.  The Toyota and Honda dealers here offer the same thing when you buy a new vehicle from them.
My dad got the same deal a long time ago down in Orlando when he purchased his 1989 GMC S15.  He got free oil changes for life.  He was at the dealer every Saturday morning when he hit 3 months.  He didn't drive it enough to reach 3k miles in that time frame.  Needless to say he did that for 10yrs.  That dealer lost money on him.  :)
I have never had the dealer change my oil. Ive had the truck 2 years now and ive getten about 4 calls "hello sir. You havent recieved any of your frew maintenance items such as oil change, tire rotarion etc" ya thanks im good broseph, i got this myself
And as for the thread. Ionly use amsoil sig series with amsoil filter
57045 WIX
0w-20 Valvoline synthetic.
I change mine when the oil life % gets to about 20%. That normally puts me around 6000 miles.
I don't believe there really is a "best" oil. Too many variables. For general purpose street use there are plenty of good oils out there that will perform well. If you have a 2018 I assume you still have powertrain warranty. A Dexos1 certified 0W-20 is all you really need. I have been using Mobil 1 since I had my last oil change done by the dealer as part of the included maintenance. I'm now at 142,000 miles. Engine runs good and oil consumption is minimum (1/2-3/4 qt every oil change which is around 7300 miles). My primary reason for using Mobil 1 is due to price. They usually have a $12 rebate on 5 quart jugs every spring and fall. They will accept Walmart purchases even though they don't list them as a participating retailer. After rebate a 5 quart jug comes out to around $13 which is hard to beat. They also offer a $17 rebate if you purchase a Mobil 1 oil filter also. This is the filter I have been using lately (M1-212A). This promotion is still going on (ends October 31st): https://mobiloil.com/en/promotion/mobil-promotions/synthetic-motor-oil-coupon
38 minutes ago, danb303 said:
57045 WIX
Yup... Same here. 20% has been just about 6000 miles.
I have used Mobil 1 in my 2003 1500HD for years. It now has 220,000 miles on it.
What's this bulletin about oil consumption?
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
