43 minutes ago, PabloK said:
Sounds good. I wish someone would put it on a 5.3 and take a video of a driveby.
I understand your frustration.. it’s hard to pull the trigger without hearing it.
I would just from my experience buying about 30 exhaust systems.
1. What you hear on the Internet/YouTube can so off on what it really sounds like in person.. I always take the videos with a grain of salt..
Secondly, I don’t know much about the differences internally between the 6.2/5.3 but I would imagine they sound fairly similar...
For anyone thinking about a Borla Exhaust system Their warranty is no joke.
I had an isue with mine recently(on truck for over 2 yrs) and after contacting them a new system was on it's way within 24 hrs.
Amazing customer service,big thanks to Chris@ Borla
I just ordered the s type for my 5.3. I’ll post some videos. Should have it by Wednesday
Not a real “cold start” but here’s a teaser. I will try to post an actual cold start and some revs when it’s not storming anymore, just didn’t have time before the rain hit.
borla s type with carbon fiber tips on a 5.3. Full disclosure, it’s paired with a K&N 63 series intake.
On 6/29/2019 at 11:50 AM, Motorhead-59 said:
I just finished helping my neighbor install the ATAK on his 2019 Silverado. We took our time and were done in just 1hr 15 minutes using a 2 post lift. Fit was great and sounds healthy on his 6.2 without being obnoxious. Nice!
Hello where you able to fully remove the stock exhaust without cutting ?
thanks
I have a four post lift and I still had to cut the exhaust in one place right behind the muffler. It might be possible to take it out in one piece with the single tailpipe exhaust but not not with the dual tailpipe exhaust.
thanks
We didn’t try to save it. I used my Sawzall and cut just in front of the front flapper valve and just behind the rear one. The stock exhaust went in the dumpster with just 400 miles on the truck.
?? I wasn’t sure if there where removable clamps on the stock where it split
I didnt have a lift. I did mine in my driveway on the ground.. Cut it like 4 times I think haha
That carbon fiber would look real cute on a Honda. I think black chrome would look better. I don’t really care about the tips performance is the key.
    • I never understood the hate for the column shifter. The console shifter just gets in the way, takes up prime cargo space and in my wife's Jeep, the dog constantly bumps the console shifter into neutral!    Best choice ever to just make it a column shifter across the lineup and be done with it.    (Bonus: Makes swapping from a 5 seater to a six seater far easier)
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
