T1 6.2 letdown?
Can you explain what makes them morons ? I love their channel and no real bias seems to be going on. They test their trucks in Colorado so the turbo motors always do best but to call them morons because gm didn’t win ?
This is my opinion dude. The guy that does the trailering stuff is pretty good. But YouTube constantly puts these three guys in my feed and every time I watch their videos they are making asses of themselves and seemingly misinformed.
  • Replies 111
35 minutes ago, SILVER SLED said:
I skimmed through second video, but did notice that it was a “rule” that they all launch in 2 wd.
The only truck that really seemed to hinder was the ecoboost. It would've killed everyone else if it could have done a brake boosted 4auto launch. Lol.
1 hour ago, SILVER SLED said:
A guy at work has a ZL1 Camaro with the 10 speed, he likes how it shifts, but says a lot of ZL1 guys say the 10 speed has a lot of torque management.
I wonder why the ZR1 Vette us use an 8 speed?
The 10 spd wont fit in the C7.
I see.
I don’t want to jinx it but my 8 speed is awesome.
3 hours ago, SILVER SLED said:
I see.
Too late ? the clunk is gonna get you. You can’t ride or hide.
Lol maybe, but I have not seen a 8 speed Silverado with the clunk yet.   There is supposedly a new fluid coming out that is supposed to fix the 8 speed woes.   I started a thread about it a couple days ago.
My gmc 6.2 8 speed shifts like butter. I have a 16 escape 2.0 turbo and that thing will beat them all. I raced a 2015 dodge 5.7 from a light to 60 and spanked him. The one thing i now love about my GMC is driving around in tow/haul mode. Feels like a whole different truck.
something's not right unless the 6.2 was loaded down or towing. the 0-60 time of the 2.0 turbo in the escape is 7.1 seconds, the 0-60 time on the 6.2 is 5.7 with the 8 speed
There is a lot of fail in this video.  First of all, none of these guys know what they are doing, total unknowing about how to race anything.  I really like their videos and they do what they can to make things close, but there are many variables they can't control.
One of the biggest problems with this video is that they are in CO waaaay above sea level.  The twin turbo f-150 one mostly because of the forced induction.
Secondly, the electronics should have been set differently.  All the nanny controls freak out.
They dont go out of their way to choose to elevation to benefit the Ford. That's where they live and test  They are transparent and state it upfront every time. Any car guy knows that forced induction will have the edge over naturally aspirated as elevation increases.
So, setting the ecoboost aside, now what is your excuse for the 6.2's showing against the Titan?
In the video it beats the titan.
Barely edged it out. Certainly didnt look like a 66 lb ft of torque and couple hundred pound less advantage to me.
Forget the 6.2, Ecoboost or any other truck in the video above.
I will show up to the drag race in this! :smash:
The Corvette uses a torque tube and transaxle set up, the Camaro features a standard style transmission that bolts directly to the engine. The reason the Vette uses a transaxle is to distribute the weight more evenly throughout the car. With the C7 platform they managed to achieve a 49-51% weight split biasing the rear, which is a remarkable achievement for a front engine car with a large V8. Makes me wonder about the purpose of the mid-engine car a little. There is no transaxle version of the 10L90 as of yet.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
