T1 6.2 letdown?
On ‎2018‎-‎11‎-‎10 at 2:08 PM, NWI Denali said:
I discovered that detent after I did the gas pedal flex mod, and i actually thought it my pedal was binding up on something after i put the shim in. Then I started googling things and found there is actually a section in the owner's manual about the kickdown detent on the 6.2. Odd that only the 6.2 has it and not the 5.3.
In my experience, when I had the stock SRA's on, if you punched the truck to pass someone on a rain covered road around 40mph, it would try to break them loose before T/C corrected it. Would the detent be there to perhaps prevent accidental "full power accelerations" when not desired? Even without punching it the truck will easily get out and walk around a transport, maybe it was an attempt at a safety feature?
Where most trucks I drive are doing maybe 120kph (74mph) when I pass a transport, the speed-o often hits 145kph (90mph) with the 6.2L. That is a huge difference.
  • Replies 111
6.2 lost to the 5.0 coyote now lol. Granted the Ford was a 2wd so a little lighter, but it also only had 3.15's. Just look in the camera view from the very last race (the second f150/sierra race) and look how strongly the coyote is pulling up top...
Here's shootout results from pickuptrucks.com done in a controlled environment. The results will surprise and go against the narrative of many here. I'm also surprised this hasn't been posted yet unless I missed it.
https://news.pickuptrucks.com/2018/11/2018-best-half-ton-truck-challenge-how-we-tested.html
A flaw in this shootout is that one of the GM's should've been a 5.3/3.23 to see how it would've stacked up especially to the Hemi/3.92. Hemi trucks are fun to drive because they set it up to be aggressive but SOTP is different than real results. You can cherry pick all day long in but there's nothing like all the trucks being run at the same time, same place with the same driver to remove the variables.
I know the SLT is 600 pounds heavier but to get pulled on up top by the smaller 5.0 is just sad.
Anyone know gears on these trucks ? By the way the Nissan sounds ****in awesome
I literally just posted that video 3 posts above you lol. And yes, how much the coyote is pulling on the 6.2 up top is disappointing. The 6.2 has 3.42's and the 5.0 has 3.15's. So that eliminates everyones usual excuse of GM's tall gearing.
Love the tfl guys
The part of this that caught my eye was how close the Chevy and the GMC were despite one having the max tow package thus the lower gears.  Also the stopping distances loaded vs unloaded were exceptionally close which doesn’t make a whole lot of sense when one has max payload in the bed.
On 11/9/2018 at 7:23 PM, GMC-AT said:
I would like to see the difference comparing the 2019 -  5.3, 8 speed vs 6.2, 10 speed.
I bet it's not that much...
Has there been a believable comparison yet?  I've seen some but not back to back under the same circumstances (elevation, temp, etc.).
Side note: I finally got around to driving a 2019 Silverado 5.3 Z71 and it felt plenty quick.  Felt about the same as my old 2016 Yukon Denal which was no slouch.  Not sure I want to pay extra for the 6.2 and continue paying for premium.
Basically no difference. Also, Ram with 3.92's might have been more comparable to a 5.3/3.23's but there's no way to substantiate it from these results. Maybe if the Ecoboost had 4.56 gears it would slayed, who knows.
boys if you want a drag car, go buy a drag car... where talkin about trucks.  its called off roading, pulling shit and hauling stuff. Come on if you want to drag down a drag strip give me a vet l1 or such and then will talk.
Drag racing is just an easy way to benchmark performance. GM claims the truck is lighter this year and has 400+ horsepower. Based on these performance tests it means to me that yes, this is probably about right. If I was really only concerned about going fast in a straight line then sure a vette would do it however I am actually interested in what the numbers say about differences between these trucks.
Myself I am mostly interested in towing performance for my 7000lbs camper. The review I quoted from above seemed to indicate the trucks are quite capable in a quantitative way and that the elusive max tow package that wasnt available on the AT4 I ordered is no great loss.
I think the differences between all of the trucks are close enough that they’ll all due the job well. To me it comes down how they actually drive, ride, then features, and styling etc.
What I like about the Ram is it’s exceptionally smooth and feels quicker than it is.  I’ve been happy with my 14 Laramie.  On the downside, they are heavy, and have limited cargo capacity compared to GM Ford etc.
The ford in the video is not representative of what most of us would buy, so I think the comparison doesn’t mean much.  The coyote can turn higher rpm, that’s usually an advantage for acceleration, as it can stay in a lower gear longer to take advantage of gearing, HP does matter and the 6.2 only has 20 more, the Ford being 600 lbs lighter is substantial.  Plus with a 10 speed the rear end ratio is not as critical and may mean the Ford with a higher rpm shift point, shifted less.  This all speculation of course.
I really like the 5.0, but my guess is the 6.2, will offer a better towing performance by having a lot more torque at lower rpm.  Which also will show itself in day to day driving as well.
Lame.  Why would you drag race a Vette when a top-fuel car is better?  Vettes are sports cars, not drag cars.  Vettes are for cruising the California coast with the top down on the weekend.
Just love it when some guy judges exactly what other people need to be doing and how lol.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
