6 minutes ago, Jamie73 said:
Is your new leaking from the top down? Or is the water pooling in the sliding glass channel?
You can look a couple of pages back but it's leaking from the top down on the drivers side.
Wow. Yet another bummer of an issue with my 2019. At this point, my truck has had a repair every month of ownership and now this. I didn't even notice the leak, but came across this post in the forums. I went out to check my truck and sure enough, 2 basketball sized water marks on my headliner, water streaks down the window and rusted rear seat mounts. Truck is at the dealer awaiting parts. I haven't been able to read all the 119 previous pages and I have a question. My dealer is saying they need to pull my rear window and reseal, pull the rear spoiler and seal, and go through the front glass with the headliner! I realize the headliner is massive (crew cab) but Im shocked at them having to pop the front window to replace it. I asked the service technician about standard procedure and he investigated and said that chevy repair docs say to open the front window to replace the headliner. He spoke with the technicians who said they could try through the back window first, but if not would have the front glass pulled and replaced as well. Can anyone who had their headliner replaced comment on the process? Is everyone also getting a new rear glass? My dealer has always done a good job and been very meticulous on my other 6 repairs, so I have no reason to doubt them.
Well first make sure the leak is "fixed" before replacing the headliner. Mine they pulled the windshield and reinstalled it on my 19. On my 20 leaker I caught it early so no damage to headliner.
It takes quite an effort to get the rear window out, if it were my truck no way I would let them reinstall it. Especially if it has cracks in the frame
Sent from my Pixel 4 using Tapatalk
My headliner went through the front window.  To replace the back glass they need to drop the headliner.  So might as well get it all done at once.
19 hours ago, UGADawgs said:
Has anyone had their window replaced with or did it come stock with the FUYAO (E4) 43R-000072 window and have this exact one leak?
There have been reports of the FUYAO E2 and the VITRO E9 leaking, but not sure I've seen the FUYAO E4 leak?
I just had mine replaced to this exact window yesterday.  Its so cold where i am that i cannot take it to a carwash for 7 days because they want to ensure the sealant/bonding agent completely cures.  They too gave me a 7yr 100K extended warranty because i was out of service for 21 days.  After getting my truck back last night I noticed the headliner is completely ruined and cracked right at the back window.  There are several scratches on the paint of the bed as well.  One area is so bad that it needs to be painted.  Dealer is going to fix the scratches and repaint if needed.  Not sure what they are going to do about the headliner because i refuse to let them take the windshield out to replace it because that just opens up the possibility to more issues.   My dealer is supposed to be one of the best in the area but i am extremely disappointed.
Edited by Ethan Fernaays
So I finally got my truck back from where they damaged a bunch of stuff when they replaced my headliner. They're still fighting me over the gouges on the passenger a pillar. In the process of fixing things, somehow they broke a piece on my rear passenger door... what the heck?
Any of you that have a sunroof, did your shade (part that covers the glass) hit the dome light after you had this procedure done? I’m assuming since the headliner had to be dropped it has something to do with it but when I slide it back now it hits. I dropped the dome light and there’s nothing in there except for the clips that hold the dome light that are hitting - which were there before.
I initially thought it could be a wire getting caught but it’s definitely hitting the light.
Any ideas of how to fix?
Thanks!
I initially thought it could be a wire getting caught but it’s definitely hitting the clips for the light.
Thanks!
On 2/28/2020 at 7:03 AM, Jamie73 said:
Hey Thomcat, you know you just jinxed yourself. My truck is great as well. All my recalls done, my 8 speed transmission is smooth as silk. Only issue is a leaking rear window that they cannot seem to fix. The TSB has been proven not to work on a lot of trucks, and like you said, if your dealer is not good, doing the TSB can lead to other issues. A leaking window is not something to worry about until it is happening to you. I just read a couple of days ago that a truck owner with 42,000 miles on his truck has started leaking. Hopefully your will stay dry, I would not wish this issue on anyone, it's a real pain in the butt. Fort Wayne, USA production, wet as a sponge.
So which one of the windows has the most problems? I have the VITRO E9 (Jun 19 build Mexico) and knock on wood hasn’t leaked. Bought the truck on 3 October.
JB
I have this same problem. Service advisor at dealer told me he had seen only two leaking windows in 2019 Silverados.  I told him there was a service bulletin and he said I was wrong there was not. Educated him and now going in next week for service.
Mine is leaking also.  The need to gut the whole truck and let it dry out.  I may try to get a new truck out of this.
Which will also leak
Had my truck in for the sealant job and not 36 hrs it was leaking again, rather than having the dealer try it again, scratch more interior panels or have to replace the window and scratch the paint etc, I decided to try something.
I wound up buying the Permatex window and glass sealant. Masked off the back window and ran a bead of it along the top of the window. The tip that comes with the tube is small enough to get in between the window and spoiler. This product is quite a bit thinner than the Kent sealant which is what I wanted to get down in every nook and cranny. Let it cure for 24 hrs before driving and waited a week to try the water test.
Time will tell but after dumping two 5 gallon buckets around the back window and spoiler it isn’t leaking at all.
I figure this probably isn’t a permanent fix, but if it can at least hold me over until GM comes up with a better fix or a new window design that doesn’t leak, it’s a win in my book.
Disclaimer: not sure if it’ll work for you and have no idea if it voids the warranty, but it is also clear and looks identical to the Kent sealant so given the non-detail oriented nature of the techs at the dealer, doubt they would notice. I wanted to have mine at least attempted to be repaired once by the dealer so it’s documented.
    doylej24
    doylej24
  • Who's Online   2 Members, 0 Anonymous, 664 Guests (See full list)
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
