This thread started Nov 14, 2018. It's been 18 months and windows are still leaking.
We need a poll for what will come first:
1) Statement from GM on why the window frames crack and what the actual solution is
2) Vaccine for Covid19
[emoji23] Definitely the Vaccine
On 5/13/2020 at 10:18 AM, hotrodz37 said:
Wow that’s bad. I went through a similar situation, bad caulk job that I got to stop leaking myself. Mine came along with damaged interior panels, paint chips and the sunroof shade no longer working.
Rear window was replaced this past week due to cracks in the frame all damaged panels replaced and feel like I’m whole again. The new tech did a fantastic job and there are actually less rattles in the truck then before which I am thankful for.
Poured all day yesterday and new window is dry - for now.
Fayuo E4 is the replacement and I have heard of people having good luck with those. If it begins to leak, most likely going to fix it myself this go round.
I'm tired of checking for water leakage every time it rains......after 14 mos. if it doesn't leak, it ain't gonna leak.
Fayuo E4 is for the glass and has nothing to do with the frame. Too bad not more pictures of the interior of the frame itself. And what's with this sealant? The number of casualties seem to be dropping off with time.......could it be that GM has already solved the problem but the solution too costly to retrolfit, let alone by half a$$ed attempts by inexperienced personnel at some dealerships? So all you get is the cheapest quick and dirty fix
I examined my frame and window carefully to compare what I could see in photos of failures. The top frame of my rear window is .065 cm or almost 3/10 of an inch thick at the spots where it typically cracks. Pretty thick to spontaneously crack....could be there is a rev on the frame and not the glass. In addition the whole frame is secured with black silicone rubber, not the snot they used to seal my leaking Silao Avalanche. Sealed to the body so tight there is no way in he!! that the dealer can remove that frame without breaking it apart and not practical to use the OEM silicone for field repair replacement installing a new frame because of prep time on surfaces, inconsistencies in bead placement and cure times........that's a job best suited for a GM robot on a freshly painted and cured surface and not some quickie job with a layer of crap they lay on top of leaking sealant that has already been compromised.
DSCN0948.JPG.51a11a92ad7678f784a4aaef7e05d786.JPGDSCN0950.JPG.b29127b1d48e45b963a3eb56c68d5ac5.JPGDSCN0953.JPG.1b705c81ab2140eb014466f53d6cfa86.JPG
Purchased a 19 Sierra at4, unfortunately I fell victim to this window leak. The truck is been at the dealership since May 8th, so its been about 10 days. Waiting on the bolts that hold the rear roof spoiler to the roof, my understanding is that the bolts have to be replaced after removing the spoiler. So that being said these bolts are on backorder with no ETA on arrival to the dealership. The truck does sit inside so I don't have to worry about more water getting in the truck, and they did give me a Camaro to drive in the mean time. But my question is has anyone had to wait for these bolts to come in and how long did it take to get some?
Bamx31, iam with you there man, mine has to have the whole rear window replaced. Brand new 2020 LT TB, they have to basically disassemble the rear cabin, seats taken out, all trim removed, haven't even made the first payment. If they damage anything, they are replacing (plastic trim) or fixing it( paint damage). .
I'm not 100% sure, I'm assuming it has something to do with sealing the spoiler to the truck better than what the assembly line put on.
@Nelly13 iam asking becuase i just fixed mine not too long ago, put a ton of blue gasket maker around the nut, hopefully it doesnt leak. The dealer gave me some nuts to put on there, he also said they are a one time thing. The ones he gave me didnt look like the ones that came off the truck(they were smaller and different design), so i just reused the originals, time will tell.
Yeah my service advisor told me they redesigned the nuts to pull the spoiler closer to help seal it better, as I've been told. Just hope they get the nuts soon. Driving a Camaro is fun but doesn't compare to these trucks.
Nelly13 ill ask him to order me some also! Yeah these t1s are badass, i love my truck man, these little problems are annoying, but hell, nothings perfect or made to last forever. Lets enjoy it while we can. Hopefully you'll get yours back soon.
I have a 2020 Silverado 1500 Z71 LT. It's certainly not a first-year problem because mine is leaking too. Same place everybody else is talking about, on the passenger, side upper right-hand corner of the rear window itself, not the slider. I live in California, the only way I noticed it was the hard water deposits dried up on the window after I washed it the second time. Not a major problem but has to be taken care of because it will get worse. I hate taking my Factory original built vehicle to those clowns at the dealer to half-ass a repair or r/r the window. It'll never be like the factory installation... But maybe that's a good thing!
Mind getting a part number for these redesigned nuts?  I hate walking into my dealership without something like a TSB or part number in hand and everyone claims to know nothing about it.
Then mine must be an odd one as that's the area I have been checking since I read this post, turns out mine is on the drivers side!
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
