3 inch Lift
z1boss
If someone could just make a lift that they confirm will work with an AT4 life would be great :)  Or at least give the explanation on why it wont.
If it's as simple as ya gotta not be a dumbass and take off the GM 2" lift, I'd understand that at least.
I agree.  I am waiting until they have lift kits available for the Trail Boss.  I would personally like another 2 inches (4 inches over stock non-Trailboss height) so that I can run 35x12.5s
Trail Boss/AT4 suspension is basically just a leveling kit. So a 6” lift would probably only result in about 4” of lift over the stock TB/AT4 suspension.
Also, a lot of lift kits reuse the stock front struts of regular trucks. Problem is the TB/AT4 has a different strut setup so the lift probably wouldn’t work unless you went with  the expensive new coil over option up front.
