19 hours ago, Chris anderson said:
Had this happen exactly as described two hours ago.  2019 Sierra Denali.  Also got an OnStar notification email noting the failure and telling me to take it in for service within 7 days.  As others have said, brakes came back but engine light stayed on.  It is now at dealership for service.
Dealer did software update:  service bulletinPIT5728B
Edited by Chris anderson
Finally somebody had a problem while backing up I have $1000 worth of damageFinally somebody had a problem while backing up I have $1000 worth of damage
I bought my 2020 Silverado RST Z71 with 3.0 Duramax on January 18, 2020. Yesterday I had the 3 message brake failure most are describing here upon push button start at 971 miles. Had no brakes at all and clicking under the dash but luckily I was off-road at the time and never accelerated past a slow idle. I restarted the truck and was left with a check engine light and the brakes were restored. I have never used the APP. to start. I drove to the dealership and got a loaner Malibu. Today the dealership called and said the truck was done. The paperwork said the updated it with PIT5730 but I did not get a copy of it of the actual TSB. Has anyone had this update with success? Thanks!
I had my recall for brakes completed today. So far, knock on wood, no problems. I’ll try starting the truck remotely and thru the app in the morning to see if the errors come up. When it happened 10k km ago, I used the Start/Stop button and it only lit up the dash when I was in the dealer car wash.
Interesting. Since PIT5728B was the last brake fix, I wonder what PIT5730 is for if they go in numerical order? I have had all the TSBs and recalls done and PIT5730 was not one of them. If anyone has paperwork or seen this PIT, please post.
Lost my power assist this morning. Engine light came on, skid control, brake warning light.
Told me not to exceed 62 mph.
Started with the app. Restarted with button. 16269 miles.
Edited by David Eifling
Have you had the most recent update performed that was released Jan 16?
I don't understand how they can say the issue was caused by the recent update when people on here have reported having the issue before having that update. That and the mention of using remote start, when once again people have reported getting the issue without using remote start. As a programmer myself I know how difficult it is to fix a problem when you don't know what causes it and it seems like they don't really know the cause here.
It’s January 29, 2020 and almost same situation with my brakes happened last night. Driving on highway, stepped on brakes to slow down, they were “spongy” or took pumping to even slow down. Pulled off and had to coast to a stop as brakes finally failed. I called Dealership service Department immediately (it’s a new pickup, have 1,000 miles on it). They sent a tow truck and towed it to their service department. I’m waiting to hear what issues are and have it repaired. I couldn’t imagine continuing to drive it even if it were to go away after sitting for a bit (I didn’t turn back on to test brakes again). At the very least it needs to be checked out and me told what is causing this, then repaired. Then repaired or a resolution to issue found. I’ll report back what they found. It was pretty shocking to be driving along then realize my brakes weren’t working. Coasting to a full stop immediately and calling service was the best decision for me. The dealership was very helpful and promptly sent a tow truck. Hopefully they continue to resolve this.
Edited by Emusedone
I typed wrong date
I have not. I’m kind of in the sweet spot on this one. Had the oil changed at a GMC dealer December 27, and I think they did three recalls at that time. Some they couldn’t do, because GM is now making them send Chevrolet products to Chevrolet dealers, apparently as part of their efforts to separate the two product lines.
I have not been notified of ANY recalls on this truck, even though this is the most dangerous defect since the Ford Pinto, in my opinion.
SORRY FELLAS I DON"T THINK THE FIX IS GOOD.
Had 18,000 miles and no problems.  Went in this Monday 1/27 for three recalls, was assured the new calibration update was NOT causing problems. Went to pick up the truck in the evening - had a check engine light for DTC U0129 lost comm brake system control module (had a scanner with me) which they claimed was NOT at all present during or after the programming.  The next day I was assured that they checked everything and did multiple test drives and found no issues. I went to pick it up again and guess what, no remote start due to current DTC's which somehow magically appeared again and nobody at the dealership could experience so I had to.  It had 13 codes, 11 from BCM, 3 from TCM and 1 from SRS.   Codes have been cleared and now I am waiting for the next problem.
So three trips to the dealer now and a truck that was working fine is F'd. I'm just waiting for my brake failure at this point.
Edited by Leevon
For me, strangely I got the notification of an available software update on my in dash screen. I didn’t hit Install Now. I wanted to wait until I was home and in the evening to download it. I got home that evening and still didn’t request to download it. But it was the next day I got in to drive it and the brakes failed. I wonder if it downloaded the update the previous night. The pickup is at the dealership now getting looked at and fixed or I’d go see if it did download it. This whole situation is stressful. I had all the screen alerts as well. I had no idea there was an issue, a recall, nothing. I haven’t heard back from them yet and I’m stranded with no vehicle. Fortunately I got a ride to my daughters home to wait. Here I sit.
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
