7 minutes ago, Jswaze88 said:
Anyone one else have their system auto update? Wonder if this will remedy the issue?
This update has been expected and it is only for the infotainment unit and associated components ie bluetooth etc.
Just wanted to update truck was at dealer for a month, same error msgs and brake issues at start up after an app or remote start we've all posted about.
Had them do PIT5728B and so far no issues with app or remote starts.
Feel nice to have my truck back after being in a base equinox for a month
Edited by Ashley6462
20 hours ago, slednchick said:
GM has offered to buy your truck back?
Yes, but I’m still waiting to hear the details because I’ve lifted it with a BDS suspension kit and put on 35’s, plus other extras, so lets see that they offer me.
Congrats.
  • Thanks 1
Yes, please let me know. GM told me for weeks that they were going to offer me a settlement... now that the "fix" is out they have changed their recommendation and I have not heard back at all.
Same here. Just picked up truck after 1 week at dealership. They performed the "yet to be released" PIT5728B reprogram/update. This should fix the issues that people have been having. Truck drives good and no issues so far.
I was told that GM has the PIT update but had not fully released it yet when mine was done. I believe the full release is today 01/22/2020. Found the bulletin info on gm site, but can't find it again.
Check with your local dealership to make sure. Heck, they may not even know about it yet. I had to tell my dealership about it and they had no idea it existed.
Hope this helps.
Dealer called me this morning and said that they have reprogrammed a dozen trucks since Thursday and no returns as of today. Taking mine in Monday.
I just had the exact failure on my 2019 Sierra SLT as everyone else has a couple of nights ago pulling out of a hospital parking lot (fitting right?!). Same lights as everyone else: "Brake System Failure 62 MPH Top Speed", "Service ESC", "Service Trailer Brake". Like some of the others I used the MyGMC app to start the truck when it occurred. I had what felt like 50% braking power when I pulled out of the parking spot so I circled the lot found another spot and stopped the truck. I haven't seen anyone mention yet that they were able to pull the codes immediately when it happened. Well luckily I have a code reader that stays in the OBDII port at all times (the speedo and tach went out on my last truck , an '08 Z71 I bought new, a couple of times so I bought a code reader that shows live data and used that for the speedo and tach).
I ran the full system diagnostic on it before I shut the truck off and had the following codes.
----Confirmed Trouble Codes Scan Report----
3 Confirmed Trouble Codes:
1. P25A2
Brake System Control Module Requested MIL Illumination
2. P0606
Control Module Processor
3. C0021
Brake Booster Performance
----Pending Trouble Codes Scan Report----
3 Pending Trouble Codes:
1. P25A2
2. P0606
3. C0021
----Permanent Trouble Codes Scan Report----
2 Permanent Trouble Codes:
1. P0606
2. C0021
I shut the truck off and restarted and got all of the same errors so I ran it again and got 3 confirmed codes, 3 pending codes, 2 permanent codes, 2 power steering control module codes, 2 transfer case control module codes, 10 Electronic Brake Control Module Codes and 2 Engine Control Module Codes.
1. P25A2
2. P0606
3. C0021
1. P25A2
2. P0606
3. C0021
1. P0606
2. C0021
----Power Steering Control Module Codes Scan Report----
2 Power Steering Control Module Trouble Codes:
1. C1512
Check report for description.
2. U0415
Invalid Data Received From Anti-Lock Brake System (ABS) Control Module
----Transfer Case Control Module Codes Scan Report----
2 Transfer Case Control Module Trouble Codes:
1. B0790
2. U0401
Invalid Data Received From ECM/PCM "A"
----Electronic Brake Control Module Codes Scan Report----
10 Electronic Brake Control Module Trouble Codes:
1. P0606
2. C0021
3. U0100
Lost Communication With ECM/PCM "A"
4. U0140
Lost Communication With Body Control Module
5. U0101
Lost Communication with TCM
6. U0131
Lost Communication With Power Steering Control Module
7. U026A
Lost Communication with Image Processing Sensor F
8. U0151
Lost Communication With Restraints Control Module
9. U0102
Lost Communication with Transfer Case Control Module
10. U0146
Lost Communication With Gateway "A"
----Engine Control Module Codes Scan Report----
2 Engine Control Module Trouble Codes:
1. P159F
2. P25A2
The brakes seemed normal the third time I restarted the truck and I drove it 45 minutes home like I was driving on black ice. Everyone behind me loved me by the way......
I am about 5 hours from home on a business trip but luckily I was able to get into a local dealer and they reprogrammed the BSCM the next morning and sent me on my way telling me not to use the app because it is known to cause issues. They also gave me the bulletin that is posted earlier in this thread as well basically stating that they are aware of the problem and that the app "may" cause an issue.
I have had so many issues with this truck and it was in the shop almost all of December. I'll list all of the issues below for your reading pleasure.
1. When using the auto-up feature on the front windows they go halfway up and then back down. (Still not fixed because dealership can't duplicate but I have video of it doing it)
2. Right turn signal stopped working and wouldn't auto cancel after turning (took 5 weeks to get the part to fix that after they said it wasn't broken initially)
3. The stereo was playing the FM radio at the same time as music being played over bluetooth or apple carplay. (Supposedly fixed with software update)
4. Speakers would sometimes not work in the truck at all for anything including OnStar (Supposedly fixed with software update)
5. Infotainment system shuts off at random times giving a black screen with no sound and will not turn back on for 5-10 minutes if at all. (Has NOT been fixed yet)
6. Has been in the shop TWICE for water leaking into the cab. (Rear window has been resealed twice and it is still not fixed and going back a third time on Monday).
7. I received a flashing Check Engine Light about two weeks after I bought the truck. The codes I pulled showed a random/multiple cylinder misfire. The shop said no codes were showing and did nothing about it. (Fixed?)
8. Sound from front brakes the other day while moving the truck in my brothers yard (before the brake system failure). The sound is difficult to describe almost like a "whirring elephant"? I dunno. (Couldn't be duplicated by dealer when they fixed the Brake System Failure issue)
I have asked GM to start the buyback/replacement process but I am  hesitant to follow through because it seems like this truck has had just about every commonly known issue go wrong with it and I don't want a "new" truck that I have to go through these problems again with.
I tried to upload the PDF's of the codes but it wouldn't let me. If anyone can help with that let me know.
Edited by SaltySLT
Clarification
  • Thanks 1
Im in a similar boat. Several major repairs and hesitant to push for buyback when several things are fixed and appear to have resolved issues. I have the feeling Id go through this all over with a new vehicle. Has anyone negotiated warranty extension or other compensation with GM customer service instead of buy back?
1. P25A2
2. P0606
3. C0021
1. P25A2
2. P0606
3. C0021
1. P0606
2. C0021
1. P25A2
2. P0606
3. C0021
1. P25A2
2. P0606
3. C0021
1. P0606
2. C0021
1. C1512
2. U0415
1. B0790
2. U0401
1. P0606
2. C0021
3. U0100
4. U0140
5. U0101
6. U0131
7. U026A
8. U0151
9. U0102
10. U0146
1. P159F
2. P25A2
First all, ensure the dealership performs the TSB PIT 5728B which will fix the problem you experienced with the brakes. Second, become familiar with the Lemon Laws of your state and get the name of a good Lemon Law Lawyer. For example Steve Lehto in Michigan is a very good lawyer for Lemons. [Has a youtube channel also]. Keep all your paperwork, documentation, any communications with the dealership, GM etc. If you do not have a OBD reader, get one allowing you to read the codes faster before they reset or disappear. This will allow you to show them to the dealer or keep for a record. The dealership may still not do anything if they cannot read them but you have the codes. There are many owners that have had no problems with their vehicles. So getting a replacement vehicle may be your best bet.
I’m still without my truck after almost a month. I don’t feel it’s incumbent upon me to have to pay the $500+ a month for a truck that spent the month at the dealership.
Has anyone had any luck pursuing this avenue of getting GM to eat a payment?
1. P25A2
2. P0606
3. C0021
1. P25A2
2. P0606
3. C0021
1. P0606
2. C0021
1. P25A2
2. P0606
3. C0021
1. P25A2
2. P0606
3. C0021
1. P0606
2. C0021
1. C1512
2. U0415
1. B0790
2. U0401
1. P0606
2. C0021
3. U0100
4. U0140
5. U0101
6. U0131
7. U026A
8. U0151
9. U0102
10. U0146
1. P159F
2. P25A2
You don't need to hire a lemon law lawyer. In the book in the glove box it explains everything you need to do to pursue a lemon law case in your state. I will tell you it is long, frustrating, and more frustrating but hopefully worth it for you in the end.  Most states require at least 30 days in the shop with 4 attempts to fix as well as a final repair attempt.
Start by filing a case with the BBB.
Send a certified letter to GM with:
FINAL REPAIR NOTICE (This statement is very important!!)
Date
Name
Address
Phone
Vin #
detail every time it has been in for service, what has been done, and how long each time you have been without the truck.
What you would like as an outcome (buy back or exchange for something else)
Signature with Date again
Keep copies of everything! Make a file and buckle up you're in for a long ride!
I have spent hours and hours and hours on this. GM will assign a rep who will ask for your patience and act like he is on your side. I am currently in the final repair attempt stage ugh I feel like this is going to drag on FOREVER!
Do you have GM financial?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
